6085 heads timing question..
Old Mar 24, 2002 | 03:32 PM
JeffC1500TBI's Avatar
ok anyone running edelbrock 6085 heads in their tbi?
I could have sworn I read somewhere in their instructions to set timing to 8* BTDC.. if that's the case then of course you have to unplug that wire for the esc and after the engine is warm leave it idle and set timing to 8 on the tab?
anyone know if this is right?
Old Mar 24, 2002 | 03:44 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Thats what the tech. sheet says. and it is a tan wire with a black stripe that you disconnect to set timming
Old Mar 24, 2002 | 07:26 PM
ok so I did read that correclty. .. I 've misplaced the sheet so I wasen't sure.. I think it said to use high octaine fuel as well. .. I just wasen't sure if advance was the number on the tab or if it was the other way.. I think my first number showing is 0 then 2,4,6,8,10 or somethign like that..
Old Mar 26, 2002 | 06:41 AM
ttt
Old Mar 26, 2002 | 01:19 PM
long&low's Avatar
Engine: TPI 350
I didn't see anything about high octane fuel.
8 deg. should be the fourth line on the tab. If I remember right.
BTW, what rockers and pushrods did you use with those heads?
Old Mar 26, 2002 | 08:29 PM
well I thought I read something about using premium fuel... maybe I'm wrong .. but if it pings with 92 octaine I'm sure it will be worse with 89 or 87.. as for pushrods I believe they are stock length.. I had the engine professionally built.. I believe he told me that the .100 rods would have been too long .. rockers I believe cam with those heads..
Old Mar 26, 2002 | 10:04 PM
long&low's Avatar
Engine: TPI 350
I will read through the papers again to make sure on the fuel thing but, I would think as they are stock replacement you shouldn't have to use premium.
are you using roller rockers? 1.5- 1.6?
Old Mar 26, 2002 | 10:49 PM
I have no idea on the rockers.. I know they are not roller though..
Old Mar 27, 2002 | 12:34 AM
boogie's Avatar
I built an engine for a 90 tbi 350 using the 6085 heads. I used the non-rail type stamped steel rockers and .100 longer than stock pushrods(geometry was good). The motor liked 8 degrees and ran fine on 89.
Lonnie
Old Mar 27, 2002 | 06:15 AM
Lonnie
edelbrock send you a custom chip for it?
Old Mar 27, 2002 | 08:42 AM
boogie's Avatar
No, I think the only way they will send you a chip is if you buy their MPFI system. I used the stock chip,3704 intake and a crane 2030 compucam(114122). I feel the truck needed some chip tuning but the guy i done the work for said he would do that later.
Lonnie
Old Mar 27, 2002 | 08:02 PM
yes if you buy the heads,cam & intake they will send you a custom chip.. but you must have all three.
Old Mar 28, 2002 | 06:29 PM
boogie's Avatar
You are correct, It has been a year or so since i done that job but i remember now wanting to use the larger crane cam, and as you mentioned, you must buy all three from edelbrock to get the chip.
Lonnie
Old Mar 28, 2002 | 08:30 PM
ok.. well edelbrock is useless in helping me out here with the pinging.. I emailed them twice and called and had to leave voice mail once.. still no hear from them...
anyhow tonight I went out and I put $25 of ultra 94 octaine to mix in with the 1/4 tank of 92 that I had in there.. still seems to ping on the initial load down for about a sec.. if I'm doing like 40kms/h and I give it half throttle it will ping just before she kicks in.. and drops the gear..
I'm thinking maybe I should drop the timing from I think it's now at 7* to maybe 5*...
using lower octain would make it worse right?
evilstuie
Jan 9, 2020 08:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
ZsTransAm
Aug 11, 2015 07:30 PM
