some blue smoke at startup
Old Mar 25, 2002 | 12:19 PM
britered86transam's Avatar
it doesnt happen all the time, but sometimes when i start up my car i get e blueish white smoke....whut could it be?
Old Mar 25, 2002 | 12:44 PM
89BlueTA's Avatar
It usually indicates worn valve seals and/or valve guides, oil is leaking past them into the cylinders. YOu can try running a thicker oil to slow down this process.
nick
Old Mar 25, 2002 | 04:34 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Don't worry about it unless your miles/quart of oil is getting grim. Even at 800 or 1000 miles to a quart it is still easier to just buy a quart now and then than to tear apart the heads.
Old Mar 25, 2002 | 06:10 PM
82camaro's Avatar
Car: 82 camaro SC
I agree with Sitting Bull, if it's not consuming alot of oil it's not hurting anything.
Old Mar 25, 2002 | 06:32 PM
camaro6spd's Avatar
up to a thicker oil.....try 10w-30....if not that then I would up it even more to 20w-50 but that is me.....hell i was running straight 50w at one point...LOL, now I replaced the valve seals (not THAT hard) and moved down to 20w-50 moble1 to help hide the oil ring worn issue till the new engine goes in this summer.....Go i hate just having that thing sit there while I blow smoke above 3500 rpms
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
gord327
Oct 3, 2015 01:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
