Effects of running with no Air Cleaner?
Old Mar 30, 2002 | 08:37 AM
primer84z's Avatar
what would be the positive/negative effects of running my carb with no air cleaner at all.
Old Mar 30, 2002 | 08:59 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Increased HP, but think of what the air cleaner does, filter out dirt in the air, so it doesn't reach the inside of the motor. Don't do it.
Old Mar 30, 2002 | 09:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Runs down the track would be the only time I'd consider it. Daily driving.....forget it.
That dirt factor
Old Mar 30, 2002 | 12:16 PM
Vader's Avatar
Your oil will get trashed inside of two weeks. The major part of contaminants in engine oil are from atmospheric dust, not internal engine or combustion particles. A good air filter is essential in long engine life.
Old Mar 30, 2002 | 01:09 PM
85 Berl's Avatar
I've also heard of cars backfiring with no filter and cleaner assembly to contain the flame and setting the car on fire. Bad deal either way.
Old Mar 30, 2002 | 01:46 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
an air filter would be like the blanket under you when you are having sex on the beach
remove that blanket and your just going to scratch the crap out of everything
Old Mar 30, 2002 | 01:59 PM
Car: 99 Formula
Axle/Gears: 342
That's one dirty mind, but true.
Old Mar 30, 2002 | 02:36 PM
rhuarc30's Avatar
Also there have been a lot of tests that show as long as you've got a good flowing filter and cleaner housing removing the air cleaner can actually hurt power because a good air cleaner smooths the air flow going into the carb.
Old Mar 31, 2002 | 12:43 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
figure that would be one of the best ways to get the point about
come on cars/sex
they go hand in hand
why do you think they made the back seat
damn you guys though I don't have one
Old Mar 31, 2002 | 12:50 AM
Car: 99 Formula
Axle/Gears: 342
That's probably why we would end up on the beach, well, back to polishing 2nd rim.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
