rear main seal oil leak
Old Mar 31, 2002 | 12:51 AM
84,86,88Z28's Avatar
hey,ijust got my new exhaust on my new project the other day,and followed my dad home,it was blowing smoke everywhere,we didnt go all that far,but anyways,got it home and there was one he// of a oil leak,it was on the drivers side,and there was oil ontop the block,where the bellhousing bolts up,so we was thinkin no gasket around the distributor,but that wasnt it,but anyways,we are working on the rear main seal now,now my question is,its around a 77 motor,"350", dipstick on drivers side,2 piece rear main right??also,are we going to have to drop the oil pan to fix this?or how do we do this??thanks for all your time.
Old Mar 31, 2002 | 01:22 AM
turningfast's Avatar
Check the valve cover gasket and the rear if the intake/block seal. If it was the rear main, it would be hard to get by thebellhousing and end up above it
Old Mar 31, 2002 | 01:33 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Make sure its not the oil sending unit or the rear of the intake manifold where it meets the block along the "china wall"
Both of these are bad leakers when they are bad, and real common.
I doubt if oil would get up on top of the bell housing with a bad rear main seal.
Old Mar 31, 2002 | 11:58 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Just what engineboy said.
I thought my rear main seal was leaking also, turns out it was the oil pressure sending unit. Easy fix, and cheap.
I'd hate to see you do all of that work, just to see that the leak is still there.
Also I have the same motor you have, just wanted to say.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
