Vadar will this be OK
Old Mar 31, 2002 | 07:34 AM
89blackbird's Avatar
I am redoing my 89 5.7 GTA and I will be using SLP headers (no air tubes) I will be taking off the aip pump to clean up the engine bay.( NY state inspection is no problem) I want to run my heater hoses as simple as possible. Can I run the top hose to the top of the engine and the bottom hose around to the oil cooler and back to the radiator? I want to get rid of the check valve and T and stuff. I want to keep it simple. Is there anyway to take the air pump off and still run my belt? Some guys say to take the guts out of the pump. Any other ways? Thanks. 89blackbird.
Old Mar 31, 2002 | 07:49 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
personally i took all the heating stuff out but if you drive it year round this isnt an option...as far as the pump check this link..........i removed mine its cake unless those torx bolts wana play dirty
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Mar 31, 2002 | 08:07 AM
Hey thats cool. What about rerunning the hoses? I do not drive the car in bad weather but do want a heater.
Old Mar 31, 2002 | 10:42 AM
wasp's Avatar
i would think if ya have long enuff hose you could run em any way ya want.....like i said i ripped all that stuff out and put in a griffin radiator so i dont even have the radiator port either......you can join hoses together to with a plastic sleeve and clamps i had to do that for my upper rad hose since i couldnt find one that was just right since the upper hose port was moved over farther to the fender on the new rad
Old Apr 1, 2002 | 12:42 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I would......
Well nevermind...let VADER answer....:hail:
xomega
Mar 23, 2006 12:21 AM
ebby53
Oct 4, 2002 07:54 AM
ebby53
Apr 14, 2002 10:28 PM
