is there a difference between 305 and 350 cruise controll parts
Old Apr 2, 2002 | 01:40 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
just like stated in the subject, is there any difference in the parts to make the cruise control work on a 305 and 350, they are vaccum operated rite? didnt know if one engine had more then the other
I ask 'cause my car is originally a 305 and I put the L98 in it, and the cruise is a lil wierd. if you read my post about "more clues to my bad idle" you'll see a lil more info about my cruise control.
Old Apr 2, 2002 | 09:18 PM
Vader's Avatar
86,
I would seriously doubt that there was any difference between the cruise servos within the same model years. The units are actuated by vacuum, but controlled by the closed-loop servo/feedback control system within the unit. The level of vacuum wouldn't matter as long as its sufficient to move the bellows, probably less than 10" Hg.
Old Apr 3, 2002 | 04:31 PM
86FyrBrd's Avatar
engines an '87 L98 my car is originally an '86 L69 (or whatever the code was for the TPI 305)
But I see your point
Old Apr 3, 2002 | 05:14 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
LB9 not L69
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
st.evel07
Aug 13, 2015 06:15 PM
Bull86
Aug 10, 2015 05:43 PM
1nastygta
Aug 8, 2015 07:38 PM
