Hardened pushrods with stock springs???
Old Apr 2, 2002 | 08:53 PM
Alan84TA's Avatar
Ok, this roller rocker install is starting to **** me off.. I just want to make sure I do it right the first time... I just got some Comp Cams Magnum roller rockers.. Putting them on my stock L69.. I pulled everything off and was getting ready to put them on and read in the instructions that you MUST replace the pushrods... So I figure I will go on and replace them. I went to a local shop and ordered some Comp Cam High-Tech (hardened) pushrods.. So I was getting ready to put them on and someone just told me that you should never install hardened pushrods with stock valve springs... @#$(#% Should I see if I can return these and order some new non-hardened pushrods?
Old Apr 2, 2002 | 09:16 PM
rezinn's Avatar
Who said that? What difference does it make? Hardened pushrods are no different than regular pushrods in function, except they are stronger. I don't see why you would need new springs to install them(although it isn't a bad idea).
Old Apr 2, 2002 | 09:18 PM
Alan84TA's Avatar
I think they ment that is it better to have them as a week point or something...
Old Apr 2, 2002 | 09:54 PM
Stroked-Z's Avatar
That someone made absolutely no sense...
Usually hardened pushrods are used when installing stiffer springs or guide plates.
It will not hurt anything nor compromise anything to install a hardened pushrod.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
