Water Pump Leak
Old Apr 4, 2002 | 10:27 PM
Buck268's Avatar
Water Pump Leak
Alright, when the cold is warming up, the water pumps leaks, REALLY bad. I suppose its most likely the gaskets, but what else could cause the, and how hard will it be to fix??? Thank you!!
Old Apr 4, 2002 | 11:03 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Well if it's leaking for the little hole in the bottom of the water pump then you need a new one. I picked up a rebuilt one for like 23 bucks I think. And don't fret about the swap, its cake.
Old Apr 5, 2002 | 04:24 AM
ede's Avatar
ede
yep if it leaks you need a new one
Old Apr 5, 2002 | 10:31 AM
Buck268's Avatar
Yeah, I kinda figured that...Damn
Old Apr 7, 2002 | 04:39 AM
bluehog67's Avatar
Car: RS
Transmission: 5 speed
I wouldn't buy a rebuilt waterpump that could go in a few months, especially with an engine with so much power. Make sure your checkin your antifreeze in your reserve, if it all leaks out and you overheat , Kiss your engine goodbye. Untill you get a new one ($47), keep some extra antifreeze in the car. Unless you have skinny arms , you'll need to put the front end up on some ramps , cause it's a bitch to try to get the pump out and the new one on from the top, you'll have to do it mostly from the bottom. Any questions email me. I know exactly what your goin through, it sucks ***.
Old Apr 9, 2002 | 05:44 PM
DeathDealer's Avatar
Car: 1992 RS Camaro
Engine: 5.0 L03 TBI 305
Ya, My waterpump is leaking right now too. I get payed on friday so I'll go ahead and order it then. Sixty bucks I think for the good one. Im letting my mechanic put it in too. It'll take a good couple hours to do it because its a pain in the butt job. Oh well. good luck
Jeremy
1992 RS
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
