89 rs that still won't run right
Old Apr 5, 2002 | 12:29 PM
dana mickelson's Avatar
po posted athread about aweek ago,about my rs that wasn,t running right, ive had quiet afew people look at it and it still is not running right, seensors are new plugs wires even distributor still no luck (by the way diagnostic code was lean mixture) the car also had strong smell of gas so we thouht it might be fuel pump, after dropping gas tank found a crack in tank, now im going to replace the tank and im hoping that will solve the problem( by the way the fuel pump will be replaced also) also would just slightly under rated fuel pressure give me this code? im lost at this point and i love the car anyone else have this problem?
Old Apr 5, 2002 | 12:37 PM
Spyder's Avatar
Humm, I don't think this would be it but its a cheap shot, have you replaced the fuel filter lately?
Old Apr 5, 2002 | 01:52 PM
come on all that i have gone through and all that someone else has gone through yes the fuel filter has been changed!?
Old Apr 5, 2002 | 05:22 PM
gas tank is the answer I,
:lala: Huarry!! I finally solved the problem!(not by myself)the dam fuel tank had a crack in it Im not sure if the fuel pump was sucking air or what , fuel pressure was o.k. but not volume all in all its finally running thank *** :lala:
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
