Weird ignition problem ?
Old Apr 8, 2002 | 02:14 AM
Blackened's Avatar
Hey everyone. Yesterday I picked up a new ignition box and installed it today. It's a Mallory HyFire VI. The newer model with the LED displays on top and the buttons that let you set all its settings.
After I installed it, it fired right up with no problem. As I drove it I noticed my tach needle bouncing around pretty violently and the engine stuterring. It's very random. At idle the needle almost goes to 0 then bounces back to idle speed and the engine almost wants to die. What's REALLY weird is that I hear these "squeeks" inside the distributor. The sound sounds exactly the same as when a wire arcs to the block or a ground point. I turned off all the lights and wanted the motor in the dark and I couldnt see any arcing at all.
I'm thinking it's probably INSIDE the cap. Don't see why though ? I'm using a stock large cap, vacuum advance HEI dizzy, with a brand new Accel coil, accel cap and rotor and 8mm spiral core Accel wires. The module is bypassed and the pickup wires are connector directly to the box.
When I had my old MSD 6A connected to it this problem wasnt there. Is it possible the box is putting out too much voltage for the coil to handle ?!? DO I need to drill holes in the cap to let all the ionized air out ? Any ideas ? :/
Old Apr 8, 2002 | 04:12 PM
Blackened's Avatar
Nobody has any ideas ? :/
Old Apr 8, 2002 | 04:32 PM
EjBaL's Avatar
sorry I dont know much about that stuff
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
Bryan F
Aug 27, 2015 07:28 AM
CORV3TT3
Aug 23, 2015 11:26 AM
