thermostat...correct install
Old Apr 8, 2002 | 09:40 PM
farm-kid/88camaro's Avatar
after my engine swap i've been having some problems with the t-stat opening.
Whats the correct way to install it? Spring up? or Spring down?
Its on a 96 vortec block, with the stock 88 pump on the serpentine belt system.
I just cant remember, and everyones telling me different things
thanks, jon
Old Apr 8, 2002 | 09:44 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Definatley spring DOWN. Thermo first, then gasket, then water neck. Good luck!
Old Apr 8, 2002 | 09:48 PM
alright, thats what i thought
must be something else wrong in the cooling system....is this ever getting annoying
if i take the t-stat out, it cools fine, put it in and it doesnt want to open up for me, it will eventually, but the temp gets up there then it finally kinda opens up abit. It seems like theres some kind of pressure problem. If i recall correctly, i have run it without the cap on and had no problems.
I'm gonna start with the hoses, anyone have any ideas?
Old Apr 8, 2002 | 10:03 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
How high is way up there, and are you dealing with a stock computer? Obviously not. Sorry. Are you using the fan shroud, and air dam under the radiator?
Old Apr 8, 2002 | 10:07 PM
its a 160 stat and doesnt open till around 240, once it opens once, temp will drop down, then in a few minutes it will rise again, but beyond 240, and repeat, getting hotter and hotter each time before it opens. Im positive the t-stat is good as its probably the 3rd one i've tried.
Rad cap is new also. Fan runs continously and air dam is in place.
It something to do with the thermostat, or incorrect pressures or something, as i can feel the fluid kind of "chugging" through the top hose as it attempts to open
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
