head job
Old Apr 8, 2002 | 10:16 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
head job
sorry to the perverts who took the subjuec the other way but that is nice to . i am getting my heads redone in 2 weeks and am gonna order the stuff like new springs up to a 500 lift ratio. all set there. some ?'s i have is should i replace the valves, how much should i expect to have bigger valves put in. i am assuming it would be extra since they would have to make the valve seat bigger. roller rockers would b nice as well just dont know which ones. 1.5 or 1.6? i have a 350 and am gonna hope to push that or more in the horsepower area. bottem end is strong. the block will most likely be bored to .040 or .060 probly the .060 since there is some deep scratches. the machinist said he wont know till he does one to see how deep it really is. but any advise will help. thanx
Old Apr 9, 2002 | 01:49 AM
rhuarc30's Avatar
Bigger valves are not cheap, but if your buying new valves anyway the valves will be around 110-300 bucks depending on what you get, plus the machine work another couple hundred, and unless you unshroud the chambers to allow them to flow they may actually hurt your power level, which means spending another couple hundred. But if your interested in what you can get check out my post on the stock L98 iron heads
https://www.thirdgen.org/techbb2/sho...threadid=97882
on the subject of your rockers, if you are only gonna go up to .5 inch lift dont' bother with 1.6 rockers, you'll quickly go over .5. I'd put springs in that were good up to at least .6 and get the valve guides cut down to accomodate the lift.
Watch your block if you have to go to .06, you may want to get it sonic checked, lotsa 350's won't go that high.
gixxer92
Sep 1, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
