Would running an MSD coil cause the plugs to go bad quicker??
Old Apr 9, 2002 | 12:33 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Would I have to replace the plugs more often running with an MSD coil? How often should they be replaced, every year?
Old Apr 10, 2002 | 10:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I always replace my plugs every year, but, when I was "just" running a higher voltage coil, the plugs showed normal wear. After I added an MSD 6AL box to that coil, my Splitfires for the past two years have gotten chewed up. I'll be moving back to regular AC plugs this spring. Here's the link of that message; looks like I wasn't the only one getting my plugs eaten: https://www.thirdgen.org/techbb2/sho...threadid=97104 But you should be fine with just a higher voltage coil!
Old Apr 10, 2002 | 05:36 PM
GreenProStreet's Avatar
If anything the plugs will where less quickly, because the hotter spark will help keep them from carbon build up from rich cylinders. The electrodes on the tips wear slowly, I think the GM figure is plugs and wires every 60,000 miles of km, not sure...
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
