Tire Sizes??
Old Apr 9, 2002 | 08:24 PM
84Z28Canada's Avatar
Tire Sizes??
I want info on tire sizing, I have standard 15 aluminium wheels, and would like to know what is the widest tire, that is close to factory height so my speedo is still close.
Old Apr 10, 2002 | 12:01 AM
darbleinad's Avatar
Car: 84 Trans Am
i cant remember the stock tire size, but i think it is 215/65R15 or something like that for my 84 Trans Am. anyway, i have 15 x7 rims and i run 255/60R15 on the back and 235/60R15 on the front. my cousin runs a real good/respected tire shop and we looked it up and 255/60R15 is the widest suggested tire size for 7" wide rims. as for the front you wouldnt want to run anything bigger than 235/60R15 or i think they would rub the wheel wells
when you turn and such. the 255s are fairly wide and i think they look fairly nice out back. i run kelly chargers..they cost me 105 each for the 255s. that included installation and balancing (no discount).
Old Apr 10, 2002 | 12:04 AM
darbleinad's Avatar
Car: 84 Trans Am
by the way man....check out the ontario board under the regional section...come say hi and post pics if you have them, post questions, etc
Old Apr 10, 2002 | 12:16 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Go to www.tirerack.com and go to the tire specs for a brand, and look at what they say is the diameter, # of revs/mile, recommended wheel widths, etc.
Here is the stuff for BFGoodrich Radial TA's
http://www.tirerack.com/tires/Spec.j...l=Radial+T%2FA
I use 235/60/R15's up front and 245/60/R15's in the rear. The speedometer isn't too far off, but it does make me feel like I'm driving slower, since the speedo says 60, and I'm actually doing 65ish (My car is too wimpy to care about the loss in overall gear ratio with the taller tire). But, the tire width and heights look better on the car than 215's do. Personally, I wouldn't even attempt any form of lower profile than stock with 15 inch wheels.
I also woulnd't try to go very wide of a tire with only 7 inch wide wheels. They would start to fit funny, and the manufacturers won't recommend it at all.
Old Apr 10, 2002 | 07:22 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i run 245/50 all around on 7 inch wide 15 rims........no probs of course you only have 2 options the bfg uro ta which is a bit shaky in the corners but wears extremely well and the stickier dunlop sport 8000.................
Old Apr 10, 2002 | 11:49 AM
Brian K's Avatar
can we see picks of your 255 50's n 15's...
Old Apr 10, 2002 | 01:40 PM
wasp's Avatar
you mean my 245/50? sure ill take some pics this weekend i dont have any layin around at the moment
Old Apr 10, 2002 | 02:13 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
235/60/15s will read correctly on the speedo if your car came wirh 215/65/15s originally...I checked it on a tire size calculator online.
Old Apr 10, 2002 | 06:06 PM
wasp's Avatar
just replace the speedo gears and use any tire ya want
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
