Transgo Shift kit.... Worth getting or not
Old Apr 9, 2002 | 08:19 PM
iroc_cragg's Avatar
Hey
I have a 1985 IROC Z Camaro with the 305 TPI engine and 3.42 gears. I am wondering if that transgo shift kit is worth getting or not. I am wondering if they are any good for thr 700R4 transmission. Will it imrove my 1/4 mile times at all. And what kind of results will I get...
P.S will I have to get a better torque converter, someone told me that
http://camaroz28.cardomain.com/id/56424
Attached Thumbnails Transgo Shift kit.... Worth getting or not-iroc5small.jpg
Old Apr 9, 2002 | 08:23 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
yes it's worth it and no you won't have to change the torque converter.
Old Apr 9, 2002 | 09:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You asked this on the tranny board, that's where I replied, but yes it's the only REAL shift kit.
Old Apr 9, 2002 | 09:12 PM
iroc_cragg's Avatar
Will the shift kit improve my ETs at all
P.S if there are any canadians out there that have a transgo shift kit can u tell me how much it cost u and where u got it from
Thanks alot
Old Apr 10, 2002 | 12:00 AM
TBI305Camaro's Avatar
ive got a transgo shift kit....sitting in my room i still havent got it in i need to tho...im hoping it keeps line pressure up if so it will improve ETs alittle....think of it like this...when you hold it in second doesnt it feel so much faster...if the shift kit does this it should help
Old Apr 10, 2002 | 12:29 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
You want the real answer? I hate mine... it upped my shift points to 6000 rpm. There is no power after 5200 rpm let alone anything at 6000 rpm. I would really suggest the parts used in the transmission of the C4 corvette's. They have a tame shift at moderate throttle and a barking screech at WOT. They can be had for very cheep, I believe about $90 or less.
Just my experience.
Old Apr 10, 2002 | 05:37 PM
zippy's Avatar
Engine: 5.3L
redirocz28, if your rpm is that high for shifting then you need to work on the governer assembly as it says in the instructions. the shift points won't always be perfect. as far as improving et's, yes it will.
Old Apr 10, 2002 | 07:02 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by zippy
redirocz28, if your rpm is that high for shifting then you need to work on the governer assembly as it says in the instructions. the shift points won't always be perfect. .
Yep. Mine needs a major recalibration, right now in D the car shift around 2500 rpms, that's why I usually manually shift when I want to go faster.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
