Water Pump sounds
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
Water Pump sounds
What kind of sounds can a bad water pump make? I know that it's bad, i just want to know what kind of sounds it can make. Thanks
Justin
Justin
You may get a howl or squeal from a failing bearing, a grinding noise from a failed bearing and/or shaft, or no noise from an impeller that has fallen off or erroded away. A leaky seal usually has no noises accompanying it either.
Car: 91 Camaro Z28
Well, I get the squeally grinding noise. But I've also got this occasional knock....but I can't pinpoint it to see if it's a rod or not. I dont' think it is, but you can never be too carefull.....It's not real loud...just kinda faint
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
