Chatter??
Old Apr 11, 2002 | 11:37 AM
jobryan26's Avatar
Chatter??
When my car reaches about 200+ degrees I get this chattering noise that I can't pinpoint. It sounds like it may be coming from passenger side of the engine compartment. It's not my lifters but something else. It chatters for a maybe 1 minute and then stops and then starts again. If it's been setting over night and I get into the car and start it up it won't chatter untill it reaches 200+ degrees. I've tried the screwdriver to the ear to search out the problem but no luck. Anyone have a clue as to what this noise is? It's driving me nuts especially at drive thru's!
87 305TPI(LB9)
Old Apr 12, 2002 | 09:28 AM
Spyder's Avatar
Do you have roller rockers and have you checked your valve lash lately?
Old Apr 12, 2002 | 09:50 AM
TBIWorks's Avatar
My 305 TBI did this, it was the smog pump bearings going out. It was intermitant and ony seemed to do it at idle with a warm engine. Start the car and get down by the smog pump with an automotive stethiscope(availible at a parts stor for 15 bucks), and listen to it. You can try it first without a steth and it might be obvious. Hope that helps, it could be something else, but the reason I think you should try this is because I knew of two other thirdgens which made the exact same noise mine did, so it must be a common issue.
Old Apr 12, 2002 | 10:44 AM
jobryan26's Avatar
Spyder yep they're rollers and no I haven't checked them in a while. Wouldn't they chatter even when it's less than 200+ degrees? I also only here it at idle when setting still.
jobryan26's Avatar
TBIWorks I've removed the Smog Pump and all emissions stuff.
novaderrik
Aug 10, 2015 12:44 PM
Hung Start67
Apr 23, 2003 04:18 AM
maksik7
Apr 19, 2003 02:43 PM
JDMZ28
Mar 6, 2001 08:14 PM
