v8? tpi?
Old Apr 11, 2002 | 12:02 PM
cridom's Avatar
v8? tpi?
how can i tell if a car is v8 305 or 350 tpi????
Old Apr 11, 2002 | 12:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll have to check the VIN, unless someone changed the motors. I believe it's the 8th digit of the VIN or 6th not sure, if it's a 350 then there will be an 8.
Old Apr 11, 2002 | 02:45 PM
TBIWorks's Avatar
8th digit of the VIN#
8 = 350
F = 305
also, there is an emessions hose routing sticker or another sticker somewhere under the hood that will have the displacement of the engine in liters printed on it in small print.
Old Apr 11, 2002 | 03:19 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Re: v8? tpi?
Well, at least in mine, it says "TUNED PORT INJECTION" really big on my motor. ;-)
Old Apr 11, 2002 | 04:42 PM
cridom's Avatar
hey fyrelance there is a 305 and 350 tuned port injection
im not asking if its a tpi or tbi so be quiet
Old Apr 11, 2002 | 05:33 PM
iroc22's Avatar
The plate that has the casting # on it of the block sitting drivers side against the firewall, will say either 5.0L or 5.7L
Old Apr 12, 2002 | 07:33 AM
FyreLance's Avatar
Re: Re: v8? tpi?
1.) In your subject you said "TPI?" with a question mark, which suggested that you were wondering if it was TPI.
2.) You will notice the winkey smiley ( ;-) ) which indicates sarcasm or joking around. I was joking with you, no need to be ****.
Old Apr 12, 2002 | 09:59 AM
camaro6spd's Avatar
good luch reading that casting by the firewall...
Old Apr 12, 2002 | 10:09 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
The 350 will have a smaller harmonic balancer then the 305. The 305 is about 1.75 to 2 inches thick.
Old Apr 12, 2002 | 03:41 PM
sIcK pUpPy's Avatar
Drive it
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
