adjusting dist on TBI 350 non 3rd gen
Old Apr 12, 2002 | 09:23 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Hey anyone have any good ideas on how your supposed to get the dist bolt loose on a 1989 blazer 350 with the TBI? the fuel lines and that stupid quick disconnect are in the way for my dist wrench to get any movement and I have the same prob with using a regular wrench. Other than removing the fuel lines or something are there any tricks to make this easy? worse thing is I dont think the bolt has EVER been loose other than when GM put it together!
thanks
Jack
Old Apr 13, 2002 | 12:25 AM
monte-ss's Avatar
anyone?
Old Apr 13, 2002 | 08:58 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
There isnt much room..but its doable
Is the timing off?
Have you checked it?
Old Apr 13, 2002 | 12:24 PM
monte-ss's Avatar
yeah the timing is off otherwise I wouldnt bother
Old Apr 13, 2002 | 01:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I did the timing on an '88 Suburban, should be similar? I used my 9/16th (IIRC) crowsfoot wrench, but didn't notice anything on it that wouldn't have allowed me to use a dis wrench on it...maybe they made a change in the years for the fuel line routing. thinking about iut, I don't recall a quick disconnect there, so more than likely there is a difference. Try a crowsfoot on the end of your extension.
Old Apr 13, 2002 | 02:56 PM
boogie's Avatar
Working from the pass side I use a long 3/8 drive extension and a 9/16 swivel socket.( be careful not to crack the bottom of the distributor cap)
Lonnie
Old Apr 13, 2002 | 03:40 PM
monte-ss's Avatar
didnt even think about the crows foot, I prob have one, but I "modified" the fuel line routing just enough to get the dist wrence to turn enough to get it to move so its all good, only prob now is the tag on the core support says 0 degrees timing with the a and B terminals connected while driving and the damn thing runs worse now that it ever did! oh well its a friends POS so he can deal with it, just put the timing back to where it was (almost 20 degrees off) and left it alone
Old Apr 13, 2002 | 11:40 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
"While driving??" I've never seen that one before...Ive seen "while in drive"
If it runs poorly at the proper timing you have other issues.
Old Apr 14, 2002 | 12:37 AM
monte-ss's Avatar
oops typo, meant to say its required to be @ 0 degrees in park/neutral and now while driving it at the timing that its required to be set at it drives worse than it did when the timing was at about 20 degrees
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
apo_bailon15
Mar 28, 2016 05:20 AM
redmaroz
Aug 16, 2015 11:40 PM
