GTech gave me 15.2 @ 99!!?? wtf?
check out my mods below. i ran it on Gtech last week and it gave me a 15.20 @ 99. Seems to me the car shouldn't be that quick. I know youre supposed to add 2 tenths to that, but thats still a 15.40? wtf?
Car: 1981 Oldsmobile Cutlass Supreme Brougham 2dr Coupe
Engine: 403 Olds v8, bored .030 over
Transmission: 350 T.H. 3A, shift kit
Sounds about right to me...
I'm not Camaro expert though. That's a 305, right? Sounds right to me. 200 something horse? 250-290 lbs/ft? Yes. sounds right.
I'll probably get a Gtech sometime in the future, but if I were you, I would perform several other tests as well.
1) If you have a place that you know is a 1/4 mile, run it and time yourself.
2)Use the little calculater test.
3)Run it a few more times on the Gtech.
Granted these are all either hokey or no iron clad, but if I got the same results...I think that it would be more convincing for you. It would be for me. Hell, I'm convinced anyway.
#1 way to know for sure is to get it to a track. Which can be difficult enough...
1 Post
Car: 99 Formula
Axle/Gears: 342
I ran a 15.32 @95mph.. Be sure the road is flat and it's in the center of the windshield.
But that will change by Friday or so.
G-Tech is pretty damn accurate. I was just at the track last night. I did five passes, all with the G-Tech running. Two of the passes were dead on with my time slips. The worst one was only off by .18 . The mph was consistently 3 - 4 mph faster according to the G-Tech, but it tells you right in the instruction manual this will happen.
Well, then I'm definitely getting one. I was just spouting off hearsay.
I'm not getting one until my cars have got a few things done though. Otherwise it won't tell me what I want and could hurt my feelings.
Car: 2001 Formula
Engine: LS2
When I started reading it I thought you were going to be dissappointed. Stock a 305 should run mid 15s and with your mods you should be low 15s like your g-tech indicated. If you still
have doubts do what Abel Kane said just to be certain and/or
take it to the track.
1 Post
Car: 1989 Iroc Z L98
1 Post
Originally posted by Mark A Shields
Yep.
Yep.
Mid 15's stock? I wish! When i had my camaro, Lo3, Flowmaster, i went to the track and my best was a 16.1. I had good reaction time, the air was good too. I don't know. My buddy has a stock 92 RS and cant break into the Mid 16's. His best has been a 16.80. But he cant drive either.
1 Post
1 Post
Car: 99 Formula
Axle/Gears: 342
Originally posted by unknown_host
what are you doing friday that is going to change things? i hope you are getting some nice heads (vortecs work nicely), their 64 cc combustion chambers will bump the compression up on the goodwrench considerably (9.x as opposed to 8.5). although if you already have a weiand intake maybe consider some other budget performance heads. so what is planned or are you just running the car again?
I won't be doing headwork till next summer. Either port these which are meaty or get new ones, money depending.
Car: 2001 Formula
Engine: LS2
TPI cars are mid 15 second cars not TBI cars people
oh well
1 Post
I just updated my sig a little prematurely. Right now the new cam is in, but I'm waitin on the gear drive and roller rockers to come in.
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
look this is the best time i ran
14.86 @ 89.5MPH
i know that mph is way slow but the reason i think is i did nto want to spin my tires because my posi is gone so i left the line like a bitch also i think im having truble with my fuel pressure
14.86 @ 89.5MPH
G-techs are only as accurate as the data you give them. If you don't have it balanced perfectly and don't have a perfectly flat, straight road, your results will not be accurate. That said, I ran 15.2 @ 94 on the gtech one time I tried it and ran 14.6 @ 95 the next day at the track. I know I screwed up.
