Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How much will I lose by?
Old Aug 26, 2002 | 08:58 PM
Falcon3's Avatar
I've got an 87 IROC 305 TPI with 700R4. I went ahead and knocked the cat out of the line, but I'm still running single exhaust. Otherwise, it's stock. For Homecoming, my friend is borrowing a 79 TransAm 400 with a Turbo400 Tranny. It's got dual exhaust and packs. Otherwise, it's stock. How will the race go?
Old Aug 26, 2002 | 09:13 PM
84CamroHO's Avatar
so the it the stock engine from 1979? or is a rebuilt GM motor?
Old Aug 26, 2002 | 09:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I didn't think there were 400s in '79?
Either way, I'd say if you got toasted by that 3.1 car, you're dead.
Old Aug 26, 2002 | 10:41 PM
Abel Kane's Avatar
Car: 1981 Oldsmobile Cutlass Supreme Brougham 2dr Coupe
Engine: 403 Olds v8, bored .030 over
Transmission: 350 T.H. 3A, shift kit
The 1979 400 TA probably has 220 hp and somewhere in the neighbourhood of 320-350 lbs/ft of torque. They weigh 3730. A guy in a Pontiac mag ran 15.27 on street tires....but he had 3.23s and a Borg Warner T-10 transmission.
Probably a low 16 second car.
By the way...how do you rid yourself of catalytic converters? It's not a difficult operation, is it? You don't have to cut or replace the rest of your exhaust system, do you?
Old Aug 27, 2002 | 10:10 PM
Falcon3's Avatar
the TA has the 400 never been rebuilt stock engine. With my cat, I cut it out with a torch, took a pipe and knocked out the honeycomb on the inside, and put it back on. Then it still looks like it has a cat, but performs like it doesn't.
Old Aug 28, 2002 | 02:36 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Not a good way to clear out cat. Because that spot in the cat that's knocked out creates a lul spot in the exhaust and accually isn't much of a performance increase at all. You would be better off just cutting the cat out and putting a staight pipe in where the cat was.
Later, Garrett
Old Aug 28, 2002 | 06:13 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Later, Garrett
but it does help if the cat is half way plugged up atleast
but yeah I agree
straight pipe instead of the cat
or put a pipe through the cat
one of the two
Old Aug 29, 2002 | 12:34 PM
90Iroc-Zee's Avatar
car craft did a test with dual 305 supercharged TPI...it gained 3 horsepower but lost 6#s feet, i only do it for the added sound
PurelyPMD
May 5, 2016 04:57 PM
Giocio
Oct 1, 2015 12:20 PM
Stryker412
Sep 20, 2015 06:59 PM
bryan623
Sep 19, 2015 10:13 AM
