Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
85 IROC vs 2001 WS6
Old Oct 29, 2002 | 05:39 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
85 IROC vs 2001 WS6
Hey guy, i'm new here, but you all seem to know quite a bit about these f-bodies. So i've got a question for you.
My friend in his WS6 wants to race my modded IROC. I just put this engine in and don't know how much power it's making. Think I should go for it?
Here's the car buildup:
former LG4
355 - L69 air cleaner(k&n) - rebuilt stand alone q-jet - weiand action plus(egr blocked) - edelbrock rpm heads - comp cams 280H magnum (230 degrees @ .05 / .480" lift) - crane gold roller rocker (1:6 ratio exhaust) - carter M6900 fuel pump - stewart water pump - hedman shorties w/ y-pipe (2.5" collector) - 3" hermoff cat - flowmaster american thunder 3" catback - auburn posi w/3.73s - rebuilt T-5 - stock ignition and distributor - clutch fan - stock ECM and chip
KYB AGX struts - Koni adjustable rear shocks - boxed lower control arms - herb adams panhard bar - suspension techniques springs
BFGoodrich comp TA Vr4s 245/50 R16 all around
Old Oct 29, 2002 | 06:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If he's an auto, and you can hook, I say you.
If he's a stick, driver's race all the way.
Old Oct 29, 2002 | 06:45 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
im gonna disagree with mark and say if hes auto it will be a drivers race and if hes stick and he can drive he'll edge you out....
Old Oct 29, 2002 | 06:49 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
I think he's got you beat. Especially if he's got an auto. Ever try launching a 6 speed LS1 car?
Old Oct 29, 2002 | 07:08 PM
Car: 99 Formula
Axle/Gears: 342
Manic Z should be quite capable of low 13s with traction.
Aluminum heads, very nice cam, 3:73s, t-5, full exhaust, not too sure about that carb though, if worked over can perform nicely.
Old Oct 29, 2002 | 07:38 PM
curt86iroc's Avatar
Car: 1990 IROC
thats just where an LS1 should be with traction also...
Old Oct 29, 2002 | 08:16 PM
my point exactly.
Old Oct 29, 2002 | 08:39 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
13.3- 13.5 is expected from stock LS1's with average drivers. Remember professional drivers are the ones who take these cars to 12.9/13.0's bone stock. I honestly think this guy has a chance, although that cam needs to be on some cylinder heads that flow a great deal on the exhaust side which performer RPMs dont do well.
A friend of mine with a similar setup except a single plane intake and a 327 with an XE284 cam (close) ran around 13.4's with street tires and 12.6's with slicks. That is definately LS1 country.
Old Oct 29, 2002 | 08:41 PM
And ditch the quadrajet unless you have done some serious work to it.
Old Oct 29, 2002 | 08:49 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by unknown_host
13.3- 13.5 is expected from stock LS1's with average drivers. Remember professional drivers are the ones who take these cars to 12.9/13.0's bone stock. I honestly think this guy has a chance, although that cam needs to be on some cylinder heads that flow a great deal on the exhaust side which performer RPMs dont do well. .
Exactly, an LS1 with traction will be low 13s same as this guy, so right there they agreed with me.
That this will be a driver's race if it's a stick.
Old Oct 29, 2002 | 08:54 PM
86IROC350NY's Avatar
I got a carb for ya
if you want mine I have a 600 CFM Holley
PN: HLY-0-80451
The holley that passes the sniffer test. electric choke, PCV, EGR etc.
all you will need to do is pay me 30 bucks and I'll pay shipping. The only thing it needs is a little rebuild. it ran better than my Street avenger I have now. i have a fuel slosh problem with my SA and i stall when my brakes are hit hard. prolly from fuel coming out of the vent tubes and causing an instant rich condition (ie flooding). i would put it back on but it is too small for my setup.
--Dan
Old Oct 29, 2002 | 09:18 PM
Car: 99 Formula
Axle/Gears: 342
Re: I got a carb for ya
PN: HLY-0-80451
--Dan
He'd be better of getting a 650DP for his setup.
Old Oct 30, 2002 | 12:49 AM
Re: Re: I got a carb for ya
yeah that is what my friend was running.
Old Oct 30, 2002 | 04:44 PM
Manic Z's Avatar
thanks...
Thanks for the guess' guys. So most of you figure that i'm probably pushing around 350 horses.
I think i'll go for the race. It's all in fun after all.
Two quick questions though;
1. Should i cut out the 2.5" collector pipe in the hedman y-pipe and put in a 3" ?
2. My timing is set to stock specs which i beleive is 0 degrees BTDC. Should i advance my timing with this engine? Also, should i upgrade my chip? Or do both?
Oh, and one more thing...is an electric fan worth any power over my clutch fan?
Old Oct 30, 2002 | 04:50 PM
Car: 99 Formula
Axle/Gears: 342
Re: thanks...
stick with the clutch fan.
Old Oct 30, 2002 | 04:52 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
well i get my top power with it four degrees after, ofcorse thats with my settup which isnt as advance as your but many of my friends cars are the same way. good luck with the race.
Old Oct 30, 2002 | 05:37 PM
curt86iroc's Avatar
Car: 1990 IROC
or better yet, a flex fan!
Old Oct 30, 2002 | 07:01 PM
MdFormula350's Avatar
post results when this race happens!! should be close..
Old Oct 31, 2002 | 04:40 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
I think it'll be a close race. Whoever hooks'll prolly win. Good Luck
Old Oct 31, 2002 | 05:25 PM
Momar's Avatar
You said something about a stand alone q-jet but also mentioned the computer as far as timing is concerned I believe. DON'T mix a non computer controlled carb with computer controlled distributer. I would either go to the computer controlled carb and do the mods listed in the tech articles on this site, or put a real aftermarket carb and distributer on there. The computer needs to be all or nothing.
Ben
Old Oct 31, 2002 | 05:44 PM
Car: 99 Formula
Axle/Gears: 342
Ben
Very good point, I wasn't sure what stand alone meant. That will make a car not run right.
Old Nov 3, 2002 | 03:41 PM
Manic Z's Avatar
finally raced
Well guys, the race finally happened.
We both went to the track this morning (Sunday), and went at it.
We only got 1 run actually. But anyway, i won.
Just barely.
Mine: 60' - 2.1 sec His: 60' - 2.2
1/4 mile 13.7 @ 102 1/4 mile 13.8 @102
The race was quite intense. Neck and neck the whole way. I couldn't even tell who won when we crossed the finish. We both left a lot of tire smoke on our launches. Not the 60' time i expected with all my suspension upgrades. Oh well.
Oh, by the way, he was a stick too with a borla exhaust. I know our times seem slower than expected, but our dragstrip is at a very high altitude. I'll look into the exact numbers. I launched at 3500 rpm because below that, the car feels like a dog, but as soon as it gets over....awesome.
Old Nov 3, 2002 | 06:38 PM
if you had a performance carb i think you woulda had him by a few more tenths. good race tho thanks for posting the outcome.
Old Nov 3, 2002 | 07:22 PM
scrawnywhiteguy's Avatar
I think you can win. But...It will most definitely be a close race.
Tim:rockon:
Oops...posted before I read all the way down to see you won. Sounds like a close shave.
Tim:rockon:
Old Nov 4, 2002 | 09:40 AM
91Firecrow305TBI's Avatar
Good job. It's always best when the race comes down to the driver. Those stock 6-speed LS1 cars put down around 315 to the wheels stock at sea level. So I'm sure your making some power.
Old Nov 4, 2002 | 10:11 AM
Car: 99 Formula
Axle/Gears: 342
Did I call it or what....:hail:
Old Nov 4, 2002 | 10:24 AM
Momar's Avatar
If he runs against an auto I guess we'll see. :lala:
Old Nov 4, 2002 | 10:39 AM
Car: 99 Formula
Axle/Gears: 342
Look at my second line there, if it's a stick, like it was, then it will be a driver's race, and it was.
Old Nov 4, 2002 | 11:07 AM
Momar's Avatar
I'm just messin with ya. I was just saying that only half of your statement has been tested.
Peace Out
neekolzun
Aug 24, 2015 04:59 PM
mcgarnicle
Aug 12, 2015 04:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
drathaar907
Aug 10, 2015 07:44 AM
