Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
'89 Formula vs. Del Sol
Old Feb 20, 2004 | 08:49 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Just wondering who do you think would win at the drag strip?
The Formula has the LO3 with a 5 speed, headers, a cutout, holley intake, ported TB, 14x3 open air, MSD blaster coil, aluminum driveshaft, and 3.08 gears
I don't know much about the Del Sol but it does have a built B14 and a 5 speed.
Thank you
Old Feb 20, 2004 | 09:40 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
never heard of a b14 I heard of b16/18 anyways if its built I think it'll take you just think if a car with the same horsepower that you have but weighing 28??lbs or maybe less
Old Feb 20, 2004 | 10:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If it is stock you will murder it. If it has any stock engine swap it will probably be close to what you run. If it is a modded swap than you will lose. Del slows aren't much threat. Plus they look just so stupid.
Old Feb 21, 2004 | 06:34 AM
vwdave's Avatar
If its a B18C series or a B16 of any type, you are screwed.
Old Feb 21, 2004 | 09:36 AM
91gta_tpi's Avatar
Car: 91 GTA
i don't know there was a guy running around town here that had a 89 CRX with a b16 del sol swap from japan that was lightly modded and he was only able to run like i think high 15's to low 16's, and he was a fairly good driver, so if you can run any better than that, then theoretically you might be able to take him.
Old Feb 21, 2004 | 01:47 PM
[superbird]
Guest
Posts: n/a
The del sol will probliby take you so I sugjest is making sure everything is concted such as vacum lines plug wires and egr.
Old Feb 21, 2004 | 04:25 PM
Engine: 5.8
I meant to say B16 and I just found out that it runs low 15's.
Linson
Oct 24, 2025 02:00 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
