Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
'02 SS vs. '87 GN vs. '87 IROC-Z
Old Dec 17, 2004 | 02:24 PM
  #51
/\/3\/\/l8l3's Avatar
was wondering if you were strapping a jet engine to the back...
Old Dec 17, 2004 | 02:25 PM
  #52
I was ls2 was more affordable and i might get onwe.
Old Dec 17, 2004 | 03:16 PM
  #53
ljnowell's Avatar
Originally posted by 25THRSS
I meant to type stock short block, not stock internals
Stock short block pretty much is stock internals. Heads dont really count as internals.
Old Dec 17, 2004 | 03:20 PM
  #54
25THRSS's Avatar
A short block is just that, the block with a bottom end. It doesn't consist of any top end engine components such as heads, cam, etc.
Old Dec 17, 2004 | 03:57 PM
  #55
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
so stock shortblock is stock internals. an yes i have heard them running real fast on stock internals minus cam. record cam only swap makes 450rwhp on stock internals. thats good for high 10's. i will try an find an example
Old Dec 17, 2004 | 04:13 PM
  #56
25THRSS's Avatar
No it doesn't. Stock internals means stock internals. Stock cam, stock heads, stock valve springs, stock pushrods, stock crank, stock rods, stock pistons, etc. Stock shortblock means stock shortblock. Does anybody even know what a shortblock is? I'll show you.
http://www.lmperformance.com/image.asp?p=12400
Old Dec 17, 2004 | 04:15 PM
  #57
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
EDIT:N/M
Old Dec 17, 2004 | 04:45 PM
  #58
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
LMAO i know what a shortblock is.
my question to u is, do you know what internals are? stock internals means crank, pistons, rods, and usually cam. these are placed in a engine block and now you have a shortblock. thus the relationship is shortblock contains stock internals, so when someone says stock internals, that means on the stock shortblock. of course they can run a aftermarket block and reuse the stock internals, but thats just dumb LOL. Vice Versa, you can say stock shortblock, which means untouched internals which means stock internals. you understand what i am saying?
Old Dec 17, 2004 | 05:08 PM
  #59
25THRSS's Avatar
no, because your understanding is wrong.
Old Dec 17, 2004 | 05:25 PM
  #60
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
not sure whos right now. you got me confused. if you go buy a zz4 shortblock, you get PM rods, 9.5 to 1 pistons, and forged steel crank for 2000 bucks. no cam and whatnot
having the fastest car on stock shortblock IS the same as stock internals. why? because the shortblock hasnt been touched. not touching the shortblock means not touching the internals inside that shortblock. the internals inside that shortblock came STOCK as is, so they are stock internals. thus a stock shortblock means stock internals as well. this is my understanding. it makes sense.
so the fastest car on as factory produced zz4 shortblock means that no internal component has been changed. that means the same pistons, rods, and crank are in there. you just bolted up heads, a cam, and intake to get your hp.
Old Dec 18, 2004 | 01:24 AM
  #61
25THRSS's Avatar
A cam and heads are internal!!!!! By what you are saying, you could take a stock L98 shortblock and bolt on a set of AFR's and a huge cam and say you have the fastest stock internal L98. Not to be rude, but uhhh no. You are confusing a shortblock with a long block, now a stock long block would be all stock internals. You need to stop thinking like the Ford guys.
Old Dec 19, 2004 | 08:40 AM
  #62
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
in the ls1 world, stock internal means stock long block. it esentially means bolt ons only. no heads no cam, no thinner head gasket, ie the motor has not been altered internally. i can understand the many diff theorys on this.
btw im giving this as info only, not as an answer to this arguement.
Galaxie500XL
Feb 1, 2020 04:53 AM
88CamZ
Oct 8, 2015 10:29 AM
86z89iroc
Oct 5, 2015 01:04 PM
Linson
Oct 1, 2015 05:33 PM
3.8TransAM
Sep 17, 2015 02:16 PM
