Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
89 Vs 94
Old Mar 14, 2005 | 03:16 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
89 Vs 94
I have a 89 Camaro with a 350 with a 700r4 witha shift kit 4 and it has a orginal qjet, single 3"custom exhuast, Headers, edlb airfilter i think its a 700 seires. I was wondering if u guys think it would beat an 94 with an lt1 ? give me some feed back
Old Mar 14, 2005 | 03:20 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
A '94 LT1 what? Be a little more specific.
Old Mar 14, 2005 | 03:25 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
I can't realy be much more spefic b/c i've only seen the car once or twicebut i think its a 94 camaro with an lt1 and its auto
Old Mar 14, 2005 | 03:32 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Well, if you got a strong running car and he's pretty much a stocker I'd say you have a really good chance
An '89 with an original qjet
Old Mar 14, 2005 | 03:39 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
yeah an 89 89 with a orginal qjet meaning i swapped out the old 2.8 and put in a 350 thta had a oringal Qjet on it
Old Mar 14, 2005 | 05:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
So the 350 you put in was not an L98? What did it come out of? That being the case, if you haven't done any head or cam work the '94 will destroy you.
Old Mar 14, 2005 | 08:43 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Originally posted by ShiftyCapone
So the 350 you put in was not an L98? What did it come out of? That being the case, if you haven't done any head or cam work the '94 will detroy you.
What he said.
Who knows what kind of power, or lack thereof, that 350 is putting out.
Old Mar 16, 2005 | 03:30 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
It is a rebuilt 84 350 and no no head or cam work what u guys think a good cam would be though looking 2 but a new one in
Old Mar 16, 2005 | 04:58 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I just did an almost identical race against my friend's 89 iroc L98, except he had a cam and chip work over you.
I pulled him out by about a car to a car and a half at 110MPH.
And my car is running like a$$.
You would be destroyed.
Old Mar 16, 2005 | 05:04 PM
ljnowell's Avatar
From a truck? More than likely, if its an 84 350, its a pretty low output engine.
Old Mar 16, 2005 | 05:15 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Yup.
Old Mar 16, 2005 | 05:16 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will get owned. Fear not, you have a great starting point to make power. You are going to want to pick a cam that matches with an intake and heads. Your motor as it sits now has 3 bottle necks. You have a full exhaust which is great but your cam, heads, and intake are weak. I would do some research to determin what power you want to make. I would suggest looking at a vortec top end with the proper carb. You could feasable do all three for around $1000 bucks.
Old Mar 17, 2005 | 10:27 AM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
"if you haven't done any head or cam work the '94 will destroy you."
you do know there are 350sout there that can smash a l98 right .like the 69-72 350 300hp and 380ft.lbs or the corvette version dong 360hp and 380ft.lbs
Old Mar 17, 2005 | 11:22 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I do know that but the chances of him having on in his car are about a million to one. Plus, he already said it was a 350 from some '84 model. That would mean a crappy low output 80's vette motor or a truck/van/utility vehicle. If I were a betting man I would put the house down on the latter.
Old Mar 17, 2005 | 05:19 PM
fly89gta's Avatar
Car: 2018 Camaro SS
That's great...shame he said the motor is from an 84...
Old Mar 28, 2005 | 03:08 PM
Mgb86's Avatar
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Its out of an 84 G series van and i was thinking a/b puting vortec heads on it later but i don't have the $ for that now whats a good cam to use and i have 2 be really careful with my intake b/c i have VERY little hood clearance the way it is.
