Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
2004 Gto
Old Feb 20, 2006 | 07:24 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
2004 Gto
Has anyone with a modded third gen gone up aganist one of these bad boys?. I know a guy in town that has one, it seems very quick. He had the tires spinning pretty hard threw third gear.
Old Feb 20, 2006 | 07:32 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
through third gear? Doubtful..... A guy in my town raced me from 15 30 and i won with a l03 camaro after that i gave up. Basically all that proved was the fact that i can hook at 15-30mph better than him but, i'll take it....
He passed me while i was at full throttle later down the road at around 1/2 throttle in his car though so being as big and heavy as they are i gave him mad props.
Old Feb 20, 2006 | 07:41 PM
Car: ws6
Engine: ls1
Transmission: m6
He spun first and second and chirped third is what I meant to say. You beat him with an l03? I wouldnt think that would be possible.
Old Feb 20, 2006 | 07:55 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i ran one a 2005 on a visit to the track about 5miles before we got there lol. he pulled about 2-3 cars on me from 0-100. when we got to the track he ran a 13.6?@103. he also had intake and exhaust. i dunno i think arizona's sucky gas and air the problem with times.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
i didn't say i beat him lol, i said i won from 15-30mph then i pretty much gave up lol. He woulda killed me with ease as i stated. It was either a sloppy driver or someone who was slipping the clutch. All i know is he was wound out like crazy..... Definetly had his matted when i did. He had been trying to race me multiple times so i figured what the heck. Great low 1st gear in the 700r4 kept me ahead for about 10-15 mph lol.
Old Feb 20, 2006 | 07:58 PM
Car: ws6
Engine: ls1
Transmission: m6
Ya I know. I thought that was strange beacuse those things cook off the line and into the mid range. As you said it could have been driver error.
Old Feb 20, 2006 | 08:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They should run the same times, if not a little better, than a M6 LS1 f-body. That means 106mph traps and low 13's should be the norm. However, like all Gen III and IV motors they scream with mods. I am such a fan of the new GTO's.
Old Feb 20, 2006 | 08:21 PM
Car: ws6
Engine: ls1
Transmission: m6
I think the new 05 GTOs are capable of running high 12's in cool air. The 04's are very quick as well and should run in the low 13's as you said. Motor Trend or Car and Driver should have a shootout between an 02 WS6 or SS vs an 05 GTO. I think that would be a pretty good match up.
Old Feb 20, 2006 | 08:28 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I am sure high 12's will be acheived by someone but it will not be the norm. The LS2 makes good power but the goat is heavier than any f-body (3800+ lbs).
GM high tech performance flog of the '05 GTO
Old Feb 20, 2006 | 08:31 PM
Car: ws6
Engine: ls1
Transmission: m6
And the temps were similar to last year's GTO test, just under 90 degrees.
I am pretty sure in 60 degree weather a high 12's would be possible. Put some radials on that thing
Old Feb 21, 2006 | 11:00 AM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
In this january's gm high tech performance ran a bone stock ls2 05 gto with factory tune and factory tires with a 100 shot and ran it against a 2001 t/a with airlid, maf, full exhaust, f.a.s.t. intake and a 125 shot. The gto ran a 12.52 at 114.08 and the t/a ran a 12.85 at 117.04. Hope this helps those ls2's really scream in that gto imagine one of those in our cars
Old Feb 21, 2006 | 02:29 PM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
We had a couple nice days, several weeks back and I happened upon a '04 GTO. He was making a right so I followed. As I pulled along side, he got into it so I followed suite. We were side by side until around 60 MPH. I was coming up on traffic in my lane and had to back off. He continued on to 90 or so. I caught up to him at the next light to see what mods he had and found out it was a M6 car with long tubes and Corsa cat-back. Turns out the guy works for Corsa and also has a low mileage '91 Camaro B4C/1LE. Good thing we weren't on the highway... I would have been owned bad!!! The combination of long tubes and Corsa cat-back sounded pretty damn good too!
Old Feb 21, 2006 | 02:47 PM
Car: ws6
Engine: ls1
Transmission: m6
Blu91Z28, I read the mods on your car domain page. I think you would see some pretty good gains by getting some good high flow runners along with a less restrictive intake manifold. You may even see a low 13. I pretty much have a full bolton 89 350 that runs 13.5's. Since your car is a 91 it is faster to begin with.
Old Feb 21, 2006 | 03:04 PM
Blu91Z28's Avatar
Engine: TPI 5.7 L
Funny you should mention that! I just bought some AS&M runners and a TPIS Big Mouth base port matched to the runners. I'm also adding a 2,500 stall Vigilante and a built 4L60. I'll be a couple hundred pounds lighter this year as well.
Old Feb 21, 2006 | 03:34 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
i got a ride in an '04 goat once....it moved pretty decent but you can just feel the weight around you
Old Feb 21, 2006 | 03:37 PM
Car: ws6
Engine: ls1
Transmission: m6
Let me know what you run once you get those mods in.
Old Feb 21, 2006 | 06:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
04 goats have same power as the Ls1 fbodies but are significantly heavier... 200lbs more
they only trap 103 up to 105 in the cold. mid lower 13's if you can control the wheel hop. higher 13's for mediocre drivers
Old Feb 21, 2006 | 08:06 PM
I saw a couple of them run up here at our track and the drivers had to put some major abuse to the T-56 in order to row dem goats into the high 13's...5800ft elev. respects no car.
Old Feb 21, 2006 | 08:17 PM
Car: ws6
Engine: ls1
Transmission: m6
I want to race one. Just to see what would happen. To be like my 10,000 doller car will beat your 30,000 doller car lol. Or whatever they go for
Old Feb 21, 2006 | 08:24 PM
89Iroc, have you done anything to your L98?
Old Feb 21, 2006 | 08:40 PM
Car: ws6
Engine: ls1
Transmission: m6
Indeed I do. Check out the site in the sig.......
Old Feb 21, 2006 | 08:49 PM
thats quite a list of mods there! and a very clean iroc indeed!!
Old Feb 21, 2006 | 08:56 PM
Car: ws6
Engine: ls1
Transmission: m6
Thanks, I try to keep it looking better than the avg third gen.
Old Feb 21, 2006 | 09:02 PM
we can only do our part to save the reputation of these cars.
Old Feb 21, 2006 | 09:06 PM
Car: ws6
Engine: ls1
Transmission: m6
Ya, The L98 engine is a really good engine when you get the restrictive stock bolt ons off. I usually keep the rep up around here. Ive beated two 99-04 GTs, an LT1 car, and a 300C. Going to try a 95 Vette soon. Going to need a little luck though lol
Old Feb 21, 2006 | 09:36 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
for what it's worth........
2 weeks ago i was out looking around and ran accross what i think was a new gto (it was a gto just don't know if it was new)with dealer tags on the car. after watchin whoever was driving pull away pretty hard from a stop light passing other cars i figured why not and managed to get to it at the next light.
(it was dark and that is why i can't give you all the details)
anyway the light turns green just about the time i get stopped so i started to roll matching the speed of the gto which was acclerating pretty hard put no where near full on.
next, i see the gto front end start to jump up BIG time so i dropped the hammer on the ol' girl and started pulling away. don't get me wrong it wasn't all that easy.
anway this was for about a block from about 10 to about 50(?). from some of the other stuff i have run the car was pretty darn fast. would have been fun to line up "for real" and see how it went but they seem to loose interest after that. i figured they were probably wondering what was wrong with the car. i've been chucklin about it and wondering if they took it back to the dealer the next day to have it checked out.
we all know 3rd gens are suppose to be easy. especially when the look bone stock.
Old Feb 21, 2006 | 09:39 PM
Car: ws6
Engine: ls1
Transmission: m6
Well By the summer I should be running with the stock ls1 cars. So third gens still have some ***** to them.
Old Feb 22, 2006 | 10:48 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
The very first pass with mine at 600 miles was a wheel hopping 13.6@103. After a few more trips to the track and about another 600 miles, I got that down to 13.25@105 still on a crappy 1.95. Stock tires are terrible, remind me of gatorbacks. Had I not started modding after that, I know I could've gotten a 13.1x out of my stock GTO. There have been others to get 13.1 also.
There have been bone stock '05's in the 12's also. Very hard with the stock brick tires. The ones with drag radials only are doing 12.6-.7. Not too shabby for a stock car with tires.
They are very capable cars. They do handle quite well for the weight, about as good as a F-Body but not a WS6 or 1LE car.
Old Feb 22, 2006 | 12:45 PM
Wind Charger's Avatar
Car: 1988 GTA TRANS AM, 1986 TRANS AM
Engine: L98, 5.7 TPI reborn, comp cam/heads maybe HSR this spring 5.0 TPI
Thats what I like to hear. Keep up the good job man!
gixxer92
Apr 12, 2022 12:09 AM
dbrochard
Oct 1, 2015 01:11 AM
