Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Dynojet Base Run
Old May 5, 2006 | 04:07 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
d
I
Old May 5, 2006 | 06:27 PM
stu's Avatar
stu
That's INSANE!
Old May 5, 2006 | 10:38 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Old May 6, 2006 | 12:28 AM
stu's Avatar
stu
Nice F'ing torque though.
So what is it like driving a car with that much more torque? It almost seems like a waste without proper amounts of horsepower to back it up.
Old May 6, 2006 | 07:48 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ever drive a diesel
they can move mountains but don't go anywhere very fast
Old May 6, 2006 | 10:51 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
TPI is always funnest between idle and 3500 RPM. Past that it doesn't go much of anywhere.
Old May 6, 2006 | 04:14 PM
Car: 87 IROC
Yup that about says it all.
Old May 6, 2006 | 04:26 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
maybe its cause I have a 305,, but it seems more like 2000 to 4000 rpm.. after that the fun kinda disappears.
Old May 6, 2006 | 09:01 PM
vwdave's Avatar
Originally Posted by rx7speed
ever drive a diesel
I think the new Cummins would like a word with you.
I highly doubt this guy got 385lb-ft at the wheels. The horsepower is a fuzz high, but the torque is off the charts.
Old May 6, 2006 | 09:59 PM
Car: '72 Chevy Nova
Transmission: TH350
385 sounds wayyyy off, especially for an auto with a super ram.
Old May 6, 2006 | 10:31 PM
Nitrous Al's Avatar
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
Post the dyno sheet.
Old May 7, 2006 | 11:18 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
i
Old May 8, 2006 | 02:15 PM
banditfirebird's Avatar
Car: 04 Dodge SRT-4, 91 formula firebird
Engine: 2.4 L4, 305 tbi
Transmission: 5-speed, 700 r4
Originally Posted by InsaneIROC
I went to the dyno today to see what i have with the stock heads,exhaust manifolds and 2 1/4 stock catback befor I put on the AFR's and the exhaust I got 224 RWH and 385 RWT. So the heads and exhaust should really wake her up.
Was it one of those mobile dynos? I think those arent as accurate for some reason. No lie i know a guy with a 1991 Chevy 1500 with a 350 tbi and he dynoed 150hp and 650 lbs of tq. No you tell me that isnt WAY off. The guy wouldnt let him do it again either.
Old May 8, 2006 | 02:40 PM
stu's Avatar
stu
That's like something you'd see at a carnival or something. lol
Old May 8, 2006 | 05:51 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
Seriously, once i hit 4k rpm i always look at the tach cause i feel like im not accelerating any more i kinda wish it shifted at like 4300rpm or something instead of 5k
Old May 8, 2006 | 06:12 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
i
Old May 8, 2006 | 06:38 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Do you know what a stall convertor thats why I have so much TQ. If I was going to lie I would have added some hourse power.
what rpm is this torque converter of yours. what size is the torque converter and what other supporting mods do you have?
while we are at it what rpm is your torque peak as well as horsepower peak?
btw you do know just about any automatic has a stall convertor right?
Old May 8, 2006 | 07:44 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
what does a stall have to do with torque increase. they just let you get higher into the rpm band before you launch with out causing your car to power breaking, this guy is full of
Old May 8, 2006 | 10:02 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
i
Old May 8, 2006 | 11:01 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
you also realize that the dyno is going to adjust for the torque multiplication by the torque converter as welll. plus automatics generally have a higher powertrain loss then a manual as is.
Old May 8, 2006 | 11:11 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
i
Old May 8, 2006 | 11:26 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
if you know then that the dyno is going to adjust for the torque multiplication then why use the torque converter as an excuse?
Old May 8, 2006 | 11:54 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Then your plenum/runners need some work. Really go to town with a dremel, makes a big difference in the way power drops off up top. Headers help as well...
This is even more apparent with the 350...
And to the original poster: get those heads and exhaust on and post the dyno sheet!!!!
Old May 8, 2006 | 11:57 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
i
Old May 8, 2006 | 11:58 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
how did the torque converter do it's job on the dyno? sure it rotated your tranny I could do that in my mazda also. it's called a clutch. so whats your point?
Old May 9, 2006 | 12:07 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
i
Old May 9, 2006 | 12:17 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
you mean just like gears multiply torque also right?
so lets see your car is an 89 right?
comes with 345lbs/ft of torque
now in 3rd gear which is a 1.1 ratio but a stock rear end gear of 3.27 means the car puts out 1128.5lbs/ft of torque to the rear wheels due to torque multiplication so why doesn't that show up on the dyno? if you don't understand that I can explain it to you a little better.
how is this different then a torque converter? gears do the same thing right?
second you say that it multiplies toruqe but horsepower stays the same can you explain how that would happen?
third why do you resort to calling me a dumb ***? do you even really know what your talking about or do you have to resort to name calling like a little kid? and what does not knowing something make you a dumb ***? if so I'm sure that we can show everyone on this site including you is a dumb ***
Old May 9, 2006 | 01:03 AM
stu's Avatar
stu
I hate when peopel throw a fit like a little bitch and delete their posts.
Old May 9, 2006 | 02:11 AM
iroc22's Avatar
This thread seems to have taken it's final run.
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
89fast5oh
Sep 27, 2015 09:04 PM
