345HP 4.10's 5Speed.. Numbers At The Track?
Well ive got a 85 camaro 345 hp at the crank on the dyno. Ive got 4.10's in the rear with a 5 speed. Susp. is stock and so if everything else.
What E.T's Should I be running with these numbers??
Thanks,
Thanks,
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
345 hp at the crank from an L03? That took some work...
If that motor is really making that power you should be capable of easy low 13s with a good launch.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
345 is close to 300whp. it takes about 240 to go mid lower side of 13's with good tires. more like 260ish to do low 13's on slicks and good driving. with 300whp, and 3500lbs, i can see u doing high 12's if you hook great on slicks. street tires is lower mid 13's
Car: 1991 Camaro RS
Engine: Blown 355 Small Block
Transmission: They always break!
Your et will be directly related to your traction. You have the power for very high 12s to mid 13s. I dont however see you going any lower than mid 13s if you maintain reqular street tires.
Im Running A Stock T-5.
And Yes I will Be Purchasing A Pair Of Drag Radials To Throw On My Stock Rims.
So High 12's to Low 13's is where ill be running Most Likely?
Also Ive got the Stock Heads And Exhaust Manifold On Their Now Is It Worth The Money To Upgrade To Better/Alum. Heads And Shorty Headers?
Thanks Again,
Thanks Again,
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Thanks Again,
Thanks Again,
Your going to be very disappointed.
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
Originally Posted by 25thmustang
I would LOVE to hear what motor you have to get this kind of power with stock heads and stock manifolds. Someone mentioned L03, and if you think an L03 with stock heads and manifolds and bolt ons has 345 hp and will run 12s...
Or, wait...
I Think He Mentioned This Particular Engine Is A 350 Crate Fitted Into Another One Of His Cars.
K, good.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Originally Posted by hihighost
I think he mentioned this particular engine is a 350 crate fitted into another one of his cars.
Or, wait...
K, good.
Or, wait...
K, good.
If its a 354hp crate motor, Im not sure if those numbers are rated with stock manifolds or not. Figure 290-300 rwhp through the 5-speed. Those numbers should be good for 12s with a decent 60' and a driver mod.
Car: 89 GTA
Engine: 350 TPI L98
Since I see you're probably gonna race it, i strongly reccomend getting that T5 rebuilt and beefed up because its not gonna hold up to a lot of torque. It might last for a month, but theres a reason GM never used them behind 350s.
Car: 89 GTA
Engine: 350 TPI L98
Originally Posted by rocluvr0013
a t5 behind a 345 FWHP motor with sticky tires isnt going to last long, if @ all.
Car: 89 Iroc-z
Transmission: TH400
so your sayin that motor dyno'd 345hp with stock style log manifolds??? DANG! with any type of header your lookin at gaining 30-40hp easy.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If you're lookin at headers, go long or go home
But seriously 345 fwhp with stock manifolds and you'll see a big gain with headers.
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Thanks Again,
Thanks Again,
The engine was obviously not ran on the dyno on those stock log manifolds (im assuming, bc i dont see any reason why it would be) So definetely get yourself some longtubes ...
No It WAS Run On The Dyno With The Stock Heads And Manifolds. So You Guys Think The Heads And Manifolds Will Help Out alot?
This Is What The Engine Has In It: What Will Be A Combo That Matches This The Best?
Goodwrench 350 short block with 40,000 miles (part# 10067353)
Cast aluminum pistons
4 bolt main
HEADS
L-98 Cast Iron "083" casting corvette style from TPI 350 completely rebuilt.
1.94/1.50 valves
Hi-Compression 64cc combustion chambers
3 angle valve job
New springs, valve seals, guides
Milled and magna-fluxed
VALVE TRAIN
Compcam extreme energy XE268H (PN# 122422) (268/280) (224/230 duration) (.477/.480 lift) (110 degrees LSA)
1600-5800RPM
Compcam push rods, double roller timing chain set, lifters.
INTAKE
Holley Street Dominator intake manifold (HLY-300-64)
Holley Street Avenger 770cfm carb with shiney finish and electric choke (HLY-0-80770)
14" x 3"air cleaner assembly.
EXHAUST
1990 Cast Iron TPI exhaust manifolds
2.75" front Y-Pipe with single 3"cat
3.00" Flowmaster catback exhaust
IGNITION
Summit Billet aluminum HEI vacuum advance distributor with 50,000 volt electronics
Summit custom advance curve kit
Accel 300+ Spark plug 8.8mm wires.
NGK 2817 Racing spark plugs specific for this engine build correct heat range
4 bolt main
HEADS
1.94/1.50 valves
3 angle valve job
VALVE TRAIN
1600-5800RPM
INTAKE
EXHAUST
IGNITION
Car: 89 GTA
Engine: 350 TPI L98
well if you have compcam pushrods, lifters, 3 angle valve job, milled & magna fluxed, and whatever else you have done to them, then they obviously wouldnt be stock factory heads like you said. It might be the factory shell, but everyone is thinking you're saying that they are stock.
edit for: left out a word.
Engine: 350 tpi
[QUOTE=L.I.N.Y.92CAMARO]No It WAS Run On The Dyno With The Stock Heads And Manifolds. So You Guys Think The Heads And Manifolds Will Help Out alot?
Well obviously you didnt run different heads on the dyno then you plan to run in the car...
ls1's usually pick up around .5 seconds in the 1/4 with longtubes, and your in the same power range,or close enough.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
Doobie52
Sep 11, 2015 06:19 PM
