Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
My chances??
Old Jul 9, 2006 | 12:45 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
My chances??
Im just wondering what my chances would be in a race. An old friend from school just bought himself a third gen. Its a 89' RS Camaro 350 TBI auto car. Absouletly nothing done to it. He has a system in the back too. I have a 86' Camaro, fresch 2.8, ported heads and intake, K&N's, gutted air box, ghetto ram air, MSD 6AL, new plugs, wires, cap and rotor, no muffler and a high-flow cat. Im getting an adjustable FPR and a B&M shift kit soon. Also I have a decent amount of weight removed including all a/c components, back seats, fronts are fourth gen seats, no front speakers, Aluminum rims, removed the charcoal canister and EGR crap, and the battery is relocated to the back. How bad am I gonna lose or do I stand some sort of chance?? Thanks
Old Jul 9, 2006 | 01:11 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
absolutely nothing done to it? yet it has a '350' 'TBI' ?
let him down easy, it hurts to hear you have a 305
Old Jul 9, 2006 | 01:12 AM
articzap's Avatar
Car: 85 Z28
Engine: 355
drivers race if i had to say so
Old Jul 9, 2006 | 03:27 AM
Well Im not too sure if it even is a 350 but he claims it is and it says so on the air cleaner, if its a 305 thats even better. Ill have to see if I can get the code off the block or something..
Old Jul 9, 2006 | 09:32 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I could put an air cleaner on my 305 and say that it is a 408 LS1 as well. The RS never came with a 350 and if he did swap a 350 in there are a lot of things he is not telling you because a 3B0 TGI could mean a crap 70's 150hp motor running on the stock 305 chip. It could also mean a 385 fastburn 350 crate motor. I would find out some more info if you can. Look for casting numbers on the block and bedind the upper portion of the block on the driver side (kinda under the firewall) you should see a 5.0 of 5.7 stamping.
Old Jul 9, 2006 | 10:31 AM
hondastyle's Avatar
Car: Honda Accord
Transmission: 5spd
Either way 305 or 350 TBI wouldn't the V6 lose?
Old Jul 9, 2006 | 12:13 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
unless the 2.8 has some kind of power adder, i agree
Old Jul 9, 2006 | 02:52 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Even if it's a 305 or a 350, the 2.8 will get worked.
It most likely isn't a 350. Check like shifty said for the 5.0L or 5.7L casting.
Old Jul 9, 2006 | 04:22 PM
He isnt mechanicaly skilled enough to swap the engine. Its what came in the car when he bought it. If I do a 50 shot of nitrous could I pull it off, if not that then a 5-speed swap?? I have some extra cash and can afford either of them. Thanks for all input thus far.
Old Jul 9, 2006 | 04:37 PM
Car: '72 Chevy Nova
Transmission: TH350
the N20 will give you better results. In fact you'll most likely go slower with the T-5.
although imo I'd save the cash for a V8
Old Jul 9, 2006 | 04:44 PM
Alright thanks. But I thought 5-speed cars were faster?? With a good driver obviously, I started out driving stick so thought maybe it would be better. And as for the V8 swap Im gonna do that after I get home from basic when I have money. Ive put a good amount of work into the six and wouldnt mind seeing it beat a V8 F-bod...
Old Jul 9, 2006 | 04:53 PM
Car: '72 Chevy Nova
Transmission: TH350
5-speeds can typically trap a little higher if they're powershifted perfectly. There in lies the key. You have to drive perfectly. And they're very inconsistant for bracket racing. And they're harder to launch. Autos are much more consistant and easier to drag race with.
Of course, the fun factor is always much higher with a stick. That's why I bought a 6-speed Camaro
Old Jul 9, 2006 | 04:58 PM
Well I dont think Id have any trouble launching. Gonna have a posi and the tires I got a pretty chunky.. I launch with the auto at about 2500rpm just from stalling it up and it has no problem hooking with the one-legger rear...
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
djmarch
May 8, 2016 11:32 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
armybyrd
Sep 26, 2015 03:37 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
