Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Iroc 355 vs rX-7
Old Aug 28, 2006 | 08:32 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Iroc 355 vs rX-7
Gonna happen this weekend. Drag 1/4 mile. Any predictions?
The rx7 is stock except some chip work and pulleys.
My car is listed below.
Old Aug 28, 2006 | 08:42 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
What year RX-7? Is it turbo or n/a?
Old Aug 28, 2006 | 09:58 PM
83CamaroZ28kid's Avatar
Car: 83 Camaro Z28
Engine: 305 LG4
Transmission: T-5 5 speed
The Iroc's gonna take the cake. The '90 RX-7 turbo runs the quarter mile in 14.9, the '94 Rx-7 Touring runs 14.5, the '94 turbo runs an even 14 seconds. With all the mods on your car you should have no problem.
Old Aug 28, 2006 | 10:02 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
seems to me like you should take him down pretty easily and and if it is non-turbo you should be nice and stay in first the whole time to make it seem close lol j/k.
Old Aug 28, 2006 | 10:04 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I'de say this one's yours, unless he's done one of those crazy port jobs to his engine, I suppose if it's the stock peice with metal taken off it's still stock. Good luck on the run.
Old Aug 29, 2006 | 04:39 PM
Manic Z's Avatar
It's a turbo. It's the style right before the RX-8 debuted.
BTW, he's never taken it to the track yet. I doubt his drag skills are any good.
Old Aug 29, 2006 | 05:20 PM
This is going to be a good run, alot of variables could pitch it either way. Make sure to post us your results after this one.
Old Aug 29, 2006 | 06:14 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
If its stock it will be an easy kill but are you sure nothing is done to it. Almost all of them are running mods nowdays.
Old Sep 8, 2006 | 04:56 PM
Manic Z's Avatar
Race didn't happen due to rain.
Gonna try again this weekend.
Old Sep 8, 2006 | 05:13 PM
CrazyBear's Avatar
Manic your car is almost how i want to build my car. Anyways hopefully you have better luck on the weather next time.
Old Sep 9, 2006 | 02:33 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
uh shhhh I have a secret for you but uh... *looks around make sure no other import guys around* your gonna win if he is stock and you know how to drive.
but if he is modded who knows. rotary responds well to mods and even more so on a turbo rotary. but then again if he drives loike a douch then all is great for you either way I bet.
Old Sep 9, 2006 | 05:19 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
those 3rd gen FD rx7's are pretty dam quick. u better be quicker than mid 13s to reliably take one if they can drive. any mods on that 7 and it could be easy pushin 12s.
from the looks of it, u should be pretty quick urself, so i think u could have this one
Old Oct 30, 2006 | 02:01 PM
Manic Z's Avatar
Update:
Raced him 2 weeks ago.
It wasn't pretty. The RX7 got his @ss waxed.
Old Nov 1, 2006 | 01:11 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
told you so
Old Nov 1, 2006 | 03:22 PM
Demon355's Avatar
So how fast are these RX7's? Stock form and maybe an exhaust/intake mods...
Also, my buddy has an '88 RX7 N/A with just an exhaust system (racingbeat header, downpipe, cat, custom made 3" ipipe to ractive muffler). Damn thing is so loud is annoying but he has 4.10's in the back and for some reason, it seems faster than what ppl make it out to me.
Old Nov 6, 2006 | 11:52 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
first thing tell him he is just kicking himself in the *** with the 3inch i pipe
my car has run at the track a 16.4 but I have had a few problems with it when I did so. it's amazing what a loose MAF does. that or missing shifts cause I suck . that was with just a K&N style filter, header and cat removed replaced with a straight pipe to the stock rusted exhaust.
most 2nd gen rx7's are in the low low to mid 16 second range though there have been a few reported to hit high to mid 15's stock.... I donno though. the second gen turbos stock are around low 15 high 14 range and a thirdgen rx7 stock should be able to hit around a low 14 maybe a high 13 if you actually know what you are doing and can handle IRS.
moddem the turbo cars are all over the place as they respond very well to boost but also with the exhaust system even the N/A ones respond very well to exhaust systems.
Old Nov 7, 2006 | 06:15 AM
Demon355's Avatar
So that custom made 3" ipipe is hurting him? I don't think he's keeping the car now, wants a G60 swap Jetta
Old Nov 7, 2006 | 11:30 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
stock is 2 inch pipe off the block and then into a 2 1/2 pipe then split again to a 2 1/2 inch pipe
that is easily enough for this car. most turbo guys ar erunning 3" though but N/A the only way you would need it is if you are running a heavy heavy port job
Old Nov 18, 2006 | 03:29 PM
Anti-Import's Avatar
Car: 1996 Ford F-150
Engine: 300cid I-6
Transmission: Berg Warner M45
Axle/Gears: Ford 9" 2.89:1
4.10's is factory in a NA 86-91 RX-7, 4.30's is factory for a turbo 86-91 RX-7.
Old Nov 30, 2006 | 09:14 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
stick to the domestics anti-import
4.10 are stock for ALL rx7's from 86-91 except for automatics which have a 3.90 which did not come turbo in the states or the GTU's which is N/A no option car and it had 4.30
Old Nov 30, 2006 | 10:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i had a few guys on rx7 sites telling me its a close race between a FD and an LS1 fbody. stock for stock... which seems to spell BS to me, as they would need full exhaust and possibly 2psi more boost to hang. stock they say are mid 13's and what i thought they were capable of.
Old Nov 30, 2006 | 12:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Man , if that thing was boosted a bit higher or something. I would have picked the RX7 . Them things are pretty fast
Good kill man !
Old Nov 30, 2006 | 02:36 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
eh I guess mid 13's might be possible in great conditions. and it would have to be some good conditions. maybe though the fd was driving a ls1 driver who couldn't really drive?
from my understanding though supra's are around mid to low 13's not rx7's
Old Feb 10, 2007 | 10:50 PM
572_IROC's Avatar
Car: 1989 Z-28 Camaro/ T-tops
Engine: LT1.350 TPI
Axle/Gears: 4:10 Posi
yo, I am selling a 1986 Mazda RX-7 NA 5-speed for $500.
needs engine work.
It starts and then stalls.
and i think the coolant is leaking into the oil pan.
body and interior is great.
will trade for brokendown or running dirtbike or quad
email for pics.
StreetRxcer69@aim.com
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 11, 2015 03:17 PM
