Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1989 iroc-z
Old Aug 18, 2007 | 08:21 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
1989 iroc-z
Hi guys finally took my new car to the track the other night and basically i'm curious at how i compare to others with close to the same setups.
my car is a factory 305 tpi with t5 5spd, im running a set of elebrock headers and custom 3in borla exhaust. I just swapped all fluids to full synthetics, the rearend is either a 3.23 or 3.08 ratio, i beleive 3.23 but, i only did the spin check so may be either, it is posi and hooks both tires very well. Also has an aftermarket alminum driveshaft airfoil and k&n filters, 350 injectors and afpr.
anyways i couldn't get it to launch all night so the times were terrible but, my trap speeds were consistent and fairly high i beleive for what it is, i trapped at 92 mph all night all my shifts were fast and precise but, my best 60 footer was 2.34 (i know terrible should a cut 2.0 easy).
basically my question is where would my traps speeds be if i could get my 60 footer down to a 1.9 or 2.0. I trapped a best of 15.0 flat. What would my tme be if i could get it down to a 2.0 or a little lower (very minimal track experience here) basically curious how mine stacks up compares to other because, it seems faster than most imo.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
88CamZ
Oct 8, 2015 10:29 AM
wanext
Oct 6, 2015 12:18 AM
