Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Best tire pressure?
Old Nov 26, 2007 | 02:22 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
Best tire pressure?
what's considered the best tire pressure for going over 100mph. i know theres a certain psi to put it at for less shaking etc.
Old Nov 26, 2007 | 02:50 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: Best tire pressure?
i would be concerned with the speeding rating on your tires and there should be a sticker in your door jam that tell you how much pressure for the front and rear tires this will give you best handleing
Old Nov 26, 2007 | 08:34 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
start with stock tire pressure. then play a little. more tire pressure up front will increase understeer. which is good because oversteer is a common problem with rear wheel drive cars. its not a huge difference in pressure between the tires though. maybe 32 up front and 30 in back.
Old Nov 26, 2007 | 11:44 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Depends on the tire. Whatever you have you need to go by its speed rating and find a happy medium between the max pressure and the stock tire inflation rate. When you get into the (Max 44 psi) tires over the usual stock 35 psi tires you will have to know what the vehicle weight with driver is and tune to your liking with about 40 psi and go from there.
Old Dec 1, 2007 | 08:26 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
I run about 20 all the time in mine..but I ahve MT ET streets..and a lot of my buddys pull up next to me at a stop light lol..but 15-20..I spin a little on spray and have 1.8s for 60 fts
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
mike_c
Aug 27, 2015 04:32 PM
g.l.mos
Aug 22, 2015 12:02 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
