Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
CAN I WIN??
Old Nov 24, 2007 | 09:47 PM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
CAN I WIN??
Ive got an 86 Iroc with 355 186 cast heads w/ 2.02 1.60 276 crane cam not sure the exact specs, TPIS Bigmouth intake 52mm tb 24lb injectors,some kind of fancy computer RAM IV I think. stock 700r4 with 3.73 gears. all this was built by previous owner, but it seems to be right. So my question is ......Can I beat a stock 95 z28 6 speed???? P.S.( Ive only had my car running for about 3 days so it still needs minor tuning but it runs pretty darn good right now) This guy has been on my A#$ wanting to race for days Should I , or will I get SPANKED?????
Old Nov 24, 2007 | 09:54 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: CAN I WIN??
Should be close. I would think it would be a drivers race, depending on how good he is at driving a manual.
Old Nov 25, 2007 | 01:08 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Re: CAN I WIN??
If the Z28 is stock you should beat him pretty well.
Old Nov 26, 2007 | 01:05 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: CAN I WIN??
If its running right, it should be a blow-out. Cam specs would tell more. You didn't mention exhaust either, I'm assuming with heads/cam you've got headers and 3" all the way back?
Old Nov 26, 2007 | 01:50 PM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
Re: CAN I WIN??
The paperwork that I have on the cam says adv 270-276 @50 210-216 deg lobe 114 and yess its 3 inch with converter still there to flowmaster
Old Nov 26, 2007 | 01:58 PM
atc3434's Avatar
Car: 1986 Camaro SC
Re: CAN I WIN??
I'd think you're well on your way to some mid-low 13 second passes, that ought to beat a stock LT-1 pretty easily. A stall converter, shift kit, and stickie tires would make things all the better.
Old Nov 26, 2007 | 02:08 PM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
Re: CAN I WIN??
Thanks for the info. I have had alot of third gens but I think this is the fastest so far, I found it sitting in some guys back yard about a month ago. Asked if it was for sale and BAM now its mine. Had to put new pump and tank and injectors. The car sat for 5 years so I think a tune-up is in order next Thanks again P.S Do you know roughly what that might run in the 1/8 if everything is right????
Old Nov 26, 2007 | 02:43 PM
atc3434's Avatar
Car: 1986 Camaro SC
Re: CAN I WIN??
What have you got for rubber? You're ability to launch is a factor for both you're quarter and 1/8th mile times. I'd guestamate real roughly 8.6 seconds in the 1/8, 13.5 in the 1/4. With a proper tuneup of course.
Old Dec 3, 2007 | 04:12 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Re: CAN I WIN??
Assuming your car runs good you will take him. I used to stay neck and neck with my friends 97 6 speed with less mods.
Old Dec 3, 2007 | 04:24 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: CAN I WIN??
Well, it sounds like your friends LT1 would go 139 if it is well taken care of, you should be able to dip into the low 13s if everything is in order tune wise. WAX HIM.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
Angie Coots
Sep 23, 2015 07:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
