1982 406 camaro vs 2005 cobra
Car: 1987 camaro, 1982 camaro
Engine: 350,406
Transmission: m-5,350 turbo
Axle/Gears: 3.73,3.73
1982 406 camaro vs 2003 cobra
Mine 1982 camaro
406 small block chevy balanced and blue printed with
k&n air filter, holley 750 carb (quick change
secondary kit installed as well as upgraded metering
plate and main jet extensions and 1" spacer) victor
jr. intake protopline cast iron heads keith black
pistons 6" eagle rods comp cams extreme energy 284 cam
heddman long tube headers into custom 3" dual exhaust
with bullet mufflers. full msd ignition with 6al box,
blaster ss coil, distributor and plug wires. bbk
underdrive pulleys weiend water pump electric fan, 140
amp polished alternator/optima battery and aluminum
aftermarket radiator.
turbo 350 with shift kit, deep aluminum pan, hughes
2500 stall converter, b&m tranny cooler and shifter.
3:73 gears and posi.
His is a 2003 mustang cobra I know he has some minor mods done to it but not sure what.
He wants to do it on street tires which I think will give him an advantage because of traction. What you guys think?
Also there is one of those mitsubishi wrx sti's that wants to have a run. I am a little nervous on this one. I was beside him on the highway on my bike (03 gsxr1000) and the thing pulled pretty hard to 277kph ( I know damn canadians lol) Not sure what he has done either except the suspension has been all re-done. But we are running the 1/4 for both races maybe 1/2 mile.
Opinions
Opinions
Engine: 350,406
Re: 1982 406 camaro vs 2005 cobra
WOW DON'T KNOW WHAT i WAS SMOKING THIS MORNING BUT IT MUST HAVE BEEN GOOD LOL.
How about Mitsubishi wrx sti and 03 cobra
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by steve29
WOW DON'T KNOW WHAT i WAS SMOKING THIS MORNING BUT IT MUST HAVE BEEN GOOD LOL.....
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
subaru wrx sti. awd turbo 5-spd. lots power but awd is slow. w/ slicks you got'em but out the hole their quick.
cobra rustang, street race he's got you. 1/4 w/ slicks all you.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I seen stock 03 cobra's dyno over 360 at the wheels with a pulley and computer upgrade they put down over 420. So you better find out what mods he has!!
You got a good combo but if you really want to wake your engine up kick out about $250 on a solid cam and lifters! An get a 3500 stall or bigger. When I changed cams to a solid on my 406 it was a night and day difference. Then I built a unbalanced 2 bolt main 355 with flattops and a used solid cam it was killing mustangs that had modded 302 and 351's.
I'm not a big fan of Protoplines I had a set an never got to use them after I did my research the just don't have the flow numbers like the other brands. But that was awhile back they might have gotten better now.
Engine: 350,406
Very informitavie Lilbowwilson any suggestions on a cam?
Guys I am pushing 435 hp now. The sti and cobra have ran the 1/4 4 times now. Don't have times but I know the sti took him everytime. Sh!@# this is going to be uglier then I thought grrrrrrr.
Car: 87 IROC
Someone said earlier that Sti's awd are slow
Car: 92 Lo3 RS
Transmission: t-5
just my exp. w/ sti. granted anything subaru makes is quick, even the forester. not related but i have seen 400+hp evo awd do poorly in 1/4, just my exp.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Assuming both the SVT and STI are stock you should beat the Suburu and lose to the Ford.
My old 2003 Cobra put down 391 rwhp bone stock through a dirty stock air filter (49k miles) and hot off the highway. I have since sold the car but two close friends of mine have an '05 M6 GTO and '05 STI. Both are stock and niether were remotely challenging for me in a race. Another friend of mine has a cat-back and CAI only '03 SVT, put down 420rwhp, and run's 12.5's.
colton_carlson
Mar 8, 2019 12:21 PM
