which gear to start off with/in?
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i am going to drag the vw jetta tonight .however never raced in a car w/ overdrive b4 . now i need to know which gear to start off in .i know its not 1 because all i will do is set there and burn out. i am thinking 2 but i am sure you guys know these cars better than me so what do i start off in and do i ever put it od?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: which gear to start off with/in?
if it's your 89 camaro, and it drives fine, just leave it in drive, it should shift just fine around 5000 rpm or so, the car will start in first by itself no matter where you put the gear selector. if you have tire spin, don't just mash the gas, roll down on it....that the basic way of doing it.
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Just leave it out of over drive all the way down the strip. If you floor it and the tires spin out bad on your first run, let off the gas a bit to get going and then floor it. Get to the track early so you can make multiple runs and and you should get better with each trip down the track. Have fun
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
just think of the automatic shifter as a limiter for the stock trans. if u put it in 2 then it wont shift past 2 and in d it wont go past drive (3rd gear 1:1 ratio) like said b4 put it into d and let it shift run a few passes to learn how to launch it and feather it off the line if need be...
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, he either sucks at driving or something .i beat him soundly .but the way that worked best was i started in second and manually went to drive .?not sure how fast the car went as i never looked down at speedo.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Leave it in "D".
If you're stupid enough to wanna manually shift an auto, may aswell start in "R".
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
well how bout a manual? t-5 wc to be exact. i heard start in one. but i heard start in 2. then i heard start in 2 to stop wheel spin, then shift down to 1st to get the high rpm boost, then shift like normal. then i heard starting in 2nd would hurt the rear end/ trans itslef, then i heard it wont. so wuts the best route when dragging a t-5 wc, and dont say switch to an atuo...please
Car: 1991 Z28 1LE
Transmission: 4l60e
first gear if u have wheelspin problems learn to feather it off the line......
Car: 1987 Chevrolet Camaro
Engine: 305 ci LG4
Transmission: TH-700R4
Axle/Gears: 2.73 non-Posi
I thought for 700r4's that when you are WOT the overdrive is disabled. Wouldn't you want to keep the overdrive to stay in the cars powerband longer during the race??
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Manual transmissions, ALWAYS start in first gear.
Unless you're running 4.10's, you wont need to shift an automatic into overdrive. Just leave it in drive until you get really good. Then you can try starting in first and bumping the shifter up to 2nd and then drive. 4th gear on a 700R4 is not very strong, and WOT will kill it.
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
hectre13
Dec 11, 2023 08:14 AM
