fresh times on my 85
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
made a few passes at the track tuesday, here's the best, i'm stocker then you think!
rt:.0849
60ft: 2.02
1/8et: 9.07
1/8mph:75.26
1/4et:14.13
1/mph:99.75
rt:.0849
60ft: 2.02
1/8et: 9.07
1/8mph:75.26
1/4et:14.13
1/mph:99.75
You may know
You may know by a handful the whole sack.--------------------------------------------------- Pet products, dog bed, pet supply wow power level, WoW Power Leveling,
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Re: fresh times on my 85
lol back from the dead. engine is a bone stock 87 l98, that i swapped into my 85 body, dunno why it runs so well but it is low miles and recently trapped over 100 breathing through the 87 intake elbow, trying for thirteens on stock engine, just need traction, to that end i just installed alston sfc's and new falken 502's, i was running those times and mph's on bald *** 225 potenza reo50's.
no headers, no work on the engine other then tune up and good wires, stock 21 yr old coil, injectors, everything.
mods are: modded ARAP tune, low restriction y pipe and cat back, 6* base timing, some suspension work but nothing that would help me hook.
oh and those times were all run wit my subwoofer box and amp in the back, prob 50 lb's sitting there but i run a camaro rs spoiler/hatch because i can't stand rotting rubber on my car nor 100 useless pounds of ugly sitting back there. most likely evens out in weight but maybe a bit lighter.
ah yea, should update my sig i guess, since the l98 is no longer in the works
