Can I beat a mopar that is better than me?
Car: GM
Engine: v8
Transmission: slushboxes
My 89 bird has a 305 tpi with the free mods, AFPR, hooker headers, no cats, 3 inch cat back, ported plenum, custom ram air intake, msd coil and wires, rebuilt trans with vette servo and transgo shift kit, AC and AIR delete, low temp thermostat, removed spare tire and jack and rear seat for weight, and got weld in subframe connectors.
My challenge is a 04 Neon SXT. I know that the SRT4 would kill me but what do I need to edge out a SXT with an AEM intake and full header back exhaust? I know he is lighter and revs higher and I know that cause he stick and I'm auto, I'm more or less screwed but what can I do for about $350 that could help me catch up? I only need to beat this car by a half a fender, not even that, maybe quarter of a fender. Please help. Maybe a 6AL box could help or something, but please help, I need to know by Friday. Thanks
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Can I beat a mopar that is better than me?
hell at best run high 15s...i ran one that had even more then the upgrades mentioned here and all he could muster was a 15.9.....
Car: 1989 i roc-z28
Engine: 350 tpi l98
a sxt? you cant be serious. i whould run a sxt in my 2.slow jetta much less my iroc. if you are going to use the 350 bucks load up some m/t et streets or a used nitrous kit.
i doubt you will need any of this , but if you want to make sure go with DR or a used wet kit
Car: 1991 Z28 1LE
Transmission: 4l60e
ok umm what makes u think an automatic will cause u to automaticly lose? automatics are better for drag racing.....the only way youll lose is if 1. break down 2. he has a lot more then mentioned 3. Your car isnt working properly....ur car should be mid to hight 14s easy...
Car: GM
Engine: v8
Well thanks guys but I still want to be sure because my car isn't a 350. I forgot to mention that I have an airfoil and a K&N filter at the end of my intake. I don't know if it helps but everybit counts, right? I also forgot one free mod, the TB coolant bypass, I need to find a 5/8 coupling I think.
I was wondering if there was anything I could take out easily to save on weight. Help please! I only have till Friday. Don't make a third gen lose to a neon!
I was wondering if there was anything I could take out easily to save on weight. Help please! I only have till Friday. Don't make a third gen lose to a neon! Supreme Member
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
If you're looking at cutting weight take an Exlax and take a huge crap.
You can easily pop out the rear seats. I really don't think you'll need to do all of that though...unless you have a seizure while driving you shouldn't lose this one.
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
1st proritie should be making certain youre car is in good tune. plugs, wires, cap + rotor, tps, iac. ect.... Do that first. Make sure you race him from a dig. And in the mean time, practice getting that thing to hook up.
Car: GM
Engine: v8
Exlax? Uh, no, that's ok, I'll pass. As far as in good tune, it is. I had to replace a gasket at the end of the driver's header connecting to the y pipe but I already did that. I have delco plugs in it cause Bosch are to expensive. It seems like I could win but what else can I do besides nitrous that will help me to win? I think I probably run low 15's high 14's cause I still get beat by my buddy's STI and he runs a 13.8 but I don't lose by much. That was before the headers and exhaust that we raced. I probably picked up a tenth so maybe I could beat the SXT. What else can I do to win?!?!
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
So hold up here. You're trying to figure out how to beat an SXT, and then what? You're going to brag about it??
Why?
Why?
Car: 2018 Camaro SS
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
Dude are you JOKING???
i beat my bodies stock 03 sxt with my firebird 3.1L auto. stock with 151k on the clock. you should kill him by lengths. and just becuase you dont got a 350 doesnt mean much. the 305tpi still got some get up and go. so stop complaining and go race him. if you do lose them its b/c of 2 things. 1) hes got alot more mods then said. 2) your just plain retarded at driving.
the 04 sxt make 132HP and 130TRQ. with his mods he might be around 150HP and 150TRQ MAYBE!!!!
the 89 305 makes 195HP and 295TRQ. with your mods you should be around 220HP and 320TRQ.
DO THE MATH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Car: 91 GTA
Axle/Gears: stock
seriously, if you're worried about losing to a basically stock neon sxt, you don't need to be racing.
theres absolutely no reason why you would lose this race.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Race him a short distance. You will pull hard on him in the beginning. I guarantee it.
Car: 2000 TRANS AM
Engine: H,C,I LS1
race him from a dig or from a roll. you will win no matter what. unless your RETARDED!
hell you can leave it in drive and still kill him.
you win. if you cant beat a sxt. then you dont belong driving a fbody. let alone a 5.0L.
i beat a 2003 sxt with a 3.1L auto.
Car: 1991 Z28 1LE
Transmission: 4l60e
Car: 1991 Z28 1LE
Transmission: 4l60e
Car: 1989 i roc-z28
Engine: 350 tpi l98
if your going to do another quick free mod take out the egr walls in the intake. when i did that i noticed a good gain
Street Lethal
Sep 7, 2015 01:09 PM
