ls1 vs l98 whats the outcome?
Car: 86 camaro irocz z28
i have my 86 z28 with a l98, full bolt ons, edlebrock high flow intake manifold, msd igntion, 3.73's, 52mm bbk tb, and a 100 shot. his is an 02 camaro z28 with high flow cats, an ls6 intake manifold, and 3.73's with street tires. i think it would be a close race from a dig but do i have a chance or what?
Re: ls1 vs l98 whats the outcome?
yea thats what im thinkin but hes sayin that his setup is producing over 400 hp. but im not buying it considering his car dynod stock at 302rwhp
Car: '84 Z28
He's prolly putting down a healthy 315-320rwhp though. Ls1's have a hell of a power band and i bet he shifts at higher rpms then you do. His manual should get him off the line pretty quick but with your mods you should be putting down a good amount of torque. Its too bad you don't have a high stall converter.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Without the spray you will get murdered. Not off the line, that will appear to be close, but he will walk you hard past that. A stock LS1 makes around 380 at the crank. Combine that with the T56 and 3.73's and you have a quick car. However, the 100 spray will make it competitive with you likely the victor.
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Im willing to bet he has close to 370 rwhp. Full bolt on minus ls6 intake makes around 325rwhp (corrected) and that intake lets them breath really good. from a dig u should get him but will still be close. but any roll above 45 u are going to have to drive perfect and hope he misses shifts/shifts slow.
Car: 2002 camaro z28
Engine: 346ci LS1
Transmission: 4L60E a4
Axle/Gears: 2.73's......
Theres no way he has 370 to the crank ALL ls1's have 345 STOCK and the 01-02's had the ls6 intake stock with his set up hes making 300-320 to the wheels give or take. It should be a close race if he can drive but, I think u might edge him out with that spray....
Car: ws6
Engine: ls1
Transmission: m6
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Most stock LS1's dyno too high for 345 to be correct. They are under rated.
Car: ws6
Engine: ls1
Transmission: m6
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
my stock ls1 dyoned 340 with lid, c/o, msd wires, ngktr55. ls6 intake and stock tb. no tune.
Car: ws6
Engine: ls1
Transmission: m6
Car: 02 SS
