91 trans am vs 2011 370Z **VID**
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Me and my brother went out with a new freind of ours with a brand new nissan 370Z to play a little. We actually weren't expecting to do as well since his carb isn't tuned to the new motor yet, but these 370's trap around 105mph in the 1/4, so I think the outcome was good for an untuned chevy 350! Trans am has a 350 with heads, cam, holley 750, T56, and 4.10's. 370Z was a stock 6 speed manual car. Heres the vid...
http://www.youtube.com/watch?v=cg5a7qzdasI
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 91 trans am vs 2011 370Z **VID**
what heads/cam? doesnt take much to get a 350 much over 105mph traps...i'd expect him to walk away easily but he didnt
Car: 1986 Trans am
Engine: 5.3 LM7
I'm sure it possibly needs more fuel at WOT as well, and the idle mixture screws havn't been touched yet.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Should be running 36* total advance, I'd have it come in sooner, JMO,....
Car: 89 Iroc-z
Transmission: TH400
well sounds like it could use a tune but those heads are large and the cam is decent sized it should be well into the low 12's all said and done, which would outrun those 370z cars anyday.
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 89 Iroc-z
Transmission: TH400
you can run alot more with aluminum heads and that compression with that cam, but only if you are certain its getting enough fuel. I dont think it is so be careful with it.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
And to think, a stock 5.3 with stock long block with a cam swapped in and a carb would walk away from that 370 with no problem, LOL.
Engine: gone
Transmission: gone
Axle/Gears: gone
thier is no set rule to timing. every motor is different therefore timing is different
Car: 91 Firebird
Engine: H/C 350
Axle/Gears: 4.10 Posi
Well True...though the 5.3 is a good engine, no denying that. But for pretty much just getting the car together and slapping on an untuned carb, I think it runs pretty well. I'm learning something new everyday with this setup and tuning it, so eventually it will be spot on and I'll get some rematch vids to see the difference.
Car: 1986 Trans am
Engine: 5.3 LM7
Good to know, and I am sure it's not getting enough fuel either since the old combo was much more mild. Wideband, here we come haha. Thanks for all the info guys. Hopefully we can get this biatch running better and have a rematch.....then post up the vid.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
