Whats a guess for 1/4 time
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
going to try to get to the track this weekend just wondering what i should expect my car is 89 formula l98 runs strong mods are stock ported base, runners and plenum along with UD pulleys air foil and cai with AFPR set at 48 lbs and stock timming for now thanks.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Whats a guess for 1/4 time
14.30 if you hook up and have a 3.23 gear. 14.6 if you dont hook up and/or have a 2.70something gear. good luck and have fun regardless of time! and remember the cars are never as fast as you'd like them to be!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
low 14's should be doable if ok traction, but with decent street tires and stock converter, it should hook up ok. If not roll into the throttle abit more.
Try stock timing and get a feel for the launch, then try adding 2 more deg to the base timing and see what happens. It should/may pick up
Car: 1999 Camaro SS
Engine: 440ci LS
Transmission: T56 Magnum
Axle/Gears: Dana S60 w/3.73 gears
Low 14s with good track prep and a good launch.
L98s come out of the hole pretty quick! Have fun man. Oh, and depending on the DA you might not run as good as normal with a lower DA.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
High 14's on street tires, low 14's on Drag radials or better....
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great thanks was hoping for low 14's, high 13's would be great what would i have to add to my current setup to run 13's
Engine: gone
Transmission: gone
Axle/Gears: gone
go run it and find out what it does. Nitrous will get you into 13's
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
