Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
ET. Estimate
Old Aug 7, 2011 | 09:01 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
ET. Estimate
69' 350 4 bolt main.Eagle rotating assembly,flat top pistons.Stock heads,ported polished and shaved.Port matched weiand x-ellerator intake. .510 lift cam,B&M 700r4 street/strip with 3000 stall.Holley 750 double pumper.K&N extreme assemblyJegs roller rockers,cloyes double roller timing chain.Holly mech fuel pump.7 psi of fuel.More mods but I just need an estimate.
85 camaro Z28,Solid motor mounts,poly trans mount,bmr control arms,panhard bar. stock 3.23 gears with shitty limited slip.M/T ET street slicks.
Running pump gas/or race fuel.
What do you think.
On the 1/8 I'm hoping for at least an 8,Is that wishful thinking?
Old Aug 8, 2011 | 01:16 AM
EvilCartman's Avatar
Car: '82 Z28
Re: ET. Estimate
Guessing high 8's, maybe. What "stock" heads are you using?
Old Aug 8, 2011 | 01:38 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: ET. Estimate
yeah compression ratio and heads are a big factor in the estimate #
Old Aug 8, 2011 | 06:19 AM
Seven_MPG's Avatar
Car: 1985 Z28
Re: ET. Estimate
Compression should be around 10.25-1.
angel2794
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
johnyIROC
May 4, 2001 11:50 AM
