Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
H/C/I 4th gen vs H/C/I 3rg gen
Old Sep 5, 2011 | 07:30 PM
10secondhopeful's Avatar
Car: '84 Z28
Friend of mine doesn't have an account but is curious about the outcome of a race between a LS1/T56 91 Camaro z28 with the following mods
mods:
short throw
k&n intake
moser 12 bolt with 4.10 gears
305/35r18 mt et streets
2" primary headers
prc stage 2.5 5.3L heads
ms4 cam
true duals
11:1 compression
tune
stock suspension, for now
and a 1999 Trans Am with:
1 7/8 LT headers
slp lip/ram air/85mm maf
ls6 intake manifold
PPTB
p&p 243 heads, milled, + springs/rr arms
short throw
ms4 cam
true duals w/cut outs
3.43 gears running 305/35/18 mt drag radials
LCA's, PHR, weld in SFC's
tune
what ya'll think?
C.
Old Sep 5, 2011 | 08:11 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: H/C/I 4th gen vs H/C/I 3rg gen
what kind of intake does the camaro have?
and he might have pretty bad wheel hop with stock suspension. i had bad wheel hop on my stock LS1
Old Sep 5, 2011 | 08:17 PM
Car: '84 Z28
Both have an LS6 intake manifold
C.
Old Sep 6, 2011 | 09:04 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The third gen will be a lot lighter than the TA most likely. That should be a big nod in his favor.
Thirdgen has no suspension upgrades?
Old Sep 6, 2011 | 04:13 PM
Convoy25's Avatar
i think with the suspension being stock puts it in favor of the 4th gen
Old Sep 6, 2011 | 05:50 PM
Car: '84 Z28
No, ran out of money, (story of our lives)
I'm the owner of the 4th gen, I'll have almost 2 years of seat time and he'll only have about a week and half after he gets back, so I have the driver mod advantage, but we're just curious about car vs car, assume the drivers are equal.
Old Sep 6, 2011 | 09:35 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Head flow, weight, and launch are going to be the determining factors in this race.
I've got some decent trap speed calculators that require the known flywheel HP and race weight.
But really those engines are pretty close depending on the head work.
Example, I can say "ported LT1 heads" for my car. But hey, they flow darn near 290cfm and just over 200cfm on the exhaust with the factory valves. Massive difference between that and a slight clean-up.
I think this one will probably come down to the driver and launch in the 1/4 mile.
Old Sep 8, 2011 | 06:35 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You can pretty much guess that a thirdgen with the exact same drivetrain and engine will be a bit faster than an equivalent 4th gen mostly because of the weight difference, probably 250lbs (maybe over 300) when comparing LS motored cars.
Old Sep 8, 2011 | 07:56 PM
Not always true. Some of the 4th gens are as light as 3rd gens. Or is it some of the 3rd gens are as heavy as 4th gens. My GTA isn't a lightweight by any stretch at 3450lbs.
Old Sep 8, 2011 | 08:34 PM
Convoy25's Avatar
my SS weighs in at 3400
even if there is a weight difference, if the 3rd gen cant hook, or put the power to the ground, it doesn't matter
Old Sep 9, 2011 | 07:02 PM
paul_huryk's Avatar
Dropping in an all aluminum LSX is worth about 150lbs over the iron SBC, so that is a drop right there.
Since the cars have a very similar suspension setup, with the same parts and tires, both are going to spin (or not).
Old Sep 9, 2011 | 08:06 PM
Convoy25's Avatar
the 4th gen has some suspension done
Old Sep 10, 2011 | 12:17 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
im going 4th gen because of the suspension mods.
Old Sep 12, 2011 | 11:47 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Wow this is a good match up of a race imo.The 4th gen has the better susp but 3:42 gear.The third gen might slightly lighter with stock susp and a 4:10 gear.The main issue I see is driver error.The 4th gen having a good 2yr seat time is a big factor.Lol how about you 2 switch cars and race eachother and see what comes out of that.Either way..I see this being a damn good race with either car maybe pulling a solid car..maybe 2 depending on how each car launches.From a roll would be interesting to hear.
Old Sep 19, 2011 | 11:48 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
The heads on the trans am have a slight advantage over the 5.3 heads on the Camaro, however the 4.10's in the Camaro will help out a lot as opposed to the 3.42 rear in the Trans Am. The MS4's love compression too, so the higher compression (assuming the compression is higher on the Camaro than the Trans Am) will definitely help.
Have either of you weight your cars?
Old Sep 27, 2011 | 03:06 PM
Marc 85Z28's Avatar
The 91 has 2" header primaries?!
As long as the 91 runs right (which many LS swaps don't) and the driver doesn't completely suck, it should easily win. The Trans Am is heavier and needs more gear.
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
