Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
GTECH HORSEPOWER
Old May 27, 2001 | 10:48 AM
KW87GTA's Avatar
GTECH HORSEPOWER
I'm just curious how this thing works and how accurate it is. I run the below car 1/4 in the mid 13's and usually at 105+, do 0-60 in 5.5 or less and I just did a horsepower reading with the GTECH for the first time. I input my weight at about 3450 with me in it and it said 203 hp. How can a car running those times only be putting 203hp. If I am correct I am supposed to hit it through a couple of gears up to redline and be accelerating hard. Is this right or am I doing something wrong. I just don't see how a car with that little power can run those times, thanks.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Superram, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Accel 24lb Injectors, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Old May 27, 2001 | 10:55 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
how did you run it when doing the dyno?
When I did it, I went 0-60 and at the time i was in the low 15's (on gtech) it said 192hp.
which sounded about right to me.
I thought the best way to do is to start at a slow roll and just bring it up through first and let off. but when we did that in my friends ranger, it got a dismal 60hp
and that thing definatly has more than 60hp.
we tryed it again with him shifting and it read 120hp. which was more reasonable with his ET's.
with you hitting 105mph, it should read ~280-290hp..
read the owners manual (i lost mine) and maybe it gives a procedure to get a more correct dyno reading.
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
scottmoyer
Sep 5, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
