Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Horsepower Estimate...
Old Jun 29, 2001 | 02:19 PM
icenine9's Avatar
Make an Estimate on this engines horsepower.
1987 355 w/four bolt main bearing caps, Stage I connecting rods, New cast crank, Hyperuetectic pistons, Edlebrok performer intake and Cam int 234 degrees .488 exh 244 degrees .510, ported heads, and roller rockers. Your guess is as good as mine. I am thinking around 320hp and 400ft/lbs at the crank.
[This message has been edited by icenine9 (edited June 29, 2001).]
Old Jun 29, 2001 | 02:28 PM
4-bolt's Avatar
What is the compression? What about fuel delivery? And exhaust? These things will determine the power along with the cam and intake manifold. Things like 4-bolt-mains, pistons and rods are all insurance. They insure that the motor will not blow to pieces or the pistons will not melt.
'87 Silverado
350 4 bolt main bore .040 over
TB Injected
Ported and Polished heads
Comp cams 268h cam and top end
Flowtech headers
3.73s on Detroit locker
Old Jun 29, 2001 | 02:35 PM
icenine9's Avatar
The Rocker arms are 1.6 ratio, the exaust is Edlebrock TES headers, through a single gutted cat to flowmaster cat-back exaust. The fuel delivery is through a Rochester 4 barrel 750cfm carb, inside a K&N Filter. The compression ratio is 9.5:1
Old Jun 29, 2001 | 11:30 PM
idrag2's Avatar
Hey guys....Please try to keep this in the board subject, I will let this one stay up for awhile though.
Later,
I Drag 2
Old Jun 30, 2001 | 05:41 AM
90Iroc-Zee's Avatar
Dump the Edelbrock and get SLP, I hate my Edelbrocks...
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air
14.4 @ 94mph w/2.0622 60ft
FOR SALE! Email me for further info.
Old Jun 30, 2001 | 01:38 PM
ImportsRsloths's Avatar
Man 90 Iroc Z you are RAGGING ON THE edelbrocks all over this board.... I dropped .3 and gaind 3 mph on the quarter on my stock 305 5 speed TPI with a hooker catback and 3" cat.
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
scottmoyer
Sep 5, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
