What will my 1/4 mile time be?
Ok, I have a 79 corvette. I rebuilt my motor and it is making about 300 hp & lbs of torque. I also have a 100hp shot of nitrous so that puts me at 400 hp & lbs of torque. It has a TH350 trans and a 3.55:1 rear end ratio. I think the car weighs 3,600 lbs or something? I can launch without wheel spin and engauge the nitrous at around 2500 rpm and it will stay hooked up. So the question, what do you think my 1/4 mile times will be?
Umm, probably 12s or 13s. But seriously, those times are with what you listed as mods and specs. Really, you should just go to the track and find out!
Don't really worry about timeslips until you get to the track. Just have some fun with your car first. I would activate nitrous at WOT, unless your WOT is at 2500 rpm, which I doubt it is.
[This message has been edited by ws6formula89 (edited August 01, 2001).]
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i could see a 13 flat out of it with no problems..of course thats just a guess since u didn't give all the info
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
The motor is a SBC 355 fresh rebuild with quadra jet carb 600-650 cfm? Wiend duel plane intake. I have the biggest cam recommeded for a stock torque converter (cant remember the exact #'s) The heads are a 1.94 intake valve 1.5 exhaust 76 cc chamber head. Flat top hyperutetic pistons. Guessing close to 9:1 compression. Duel exhaust with full length headder and cross over pipe. Torque convert is stock no stall. I am at WOT the whole time but I have to wait until 2500 maybe 2000 rpm to engage the Nitrous bucause if I did it earlier I would probably start breaking connecting rods and things of that nauture
The take off is going to really slow my time down because I have to wait to hit the Nitours and I dont have a shift kit so my shifts are a little slow and soft but it does go like hell
I guess I'm just wondering about what time I'll get but I will be going to the track hopefully this summer to find out for sure. Any more guesses on my time? I was hopeing to break into the 13's
I guess I'm just wondering about what time I'll get but I will be going to the track hopefully this summer to find out for sure. Any more guesses on my time? I was hopeing to break into the 13's Umm, I'm sure that torque converter has a stall, all torque converters have a stall. I'm guessing if it's stock, it's a 2000 (est.) rpm stall. Try powerbraking it, at the point of "stall speed", more torque will be transferred, and the wheels will most likely break loose. When that happens, what RPM that happened at, that is your stall speed.
-ws6formula-
-ws6formula-
An honest 400hp should put you in the 12s easy!!!
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
14.1@ 98MPH
OTHER RIDE
Ya, I guess I phrased that wrong. All converters would have a stall but what I was tring to get at was the converter is stock with no higher stall over what stock one would be set at. Ya when I take off I can break torque it and helps launch it off the line but it still suffers. It has a possi with 245 on the rear and the vette has good weight transfer so it is hard to get those babys to break loose. If it is a little wet, sand on the road, or turning it will break them loose and spin it pretty good.
In the 12's huh.... That would be nice
If I get mid to low 13's I would be pretty happy. I could pick some races on the street and not worry about consistantly getting my *** handed back to me
evilstuie
Jan 9, 2020 08:29 PM
