5spd launch??????
5spd launch??????
what rpm would you guys recommend dumping the clutch at to get the best launch...
now here are the specs:
92 RS
3.1L
5spd
3.42 rear (single tire fryer)
good road hugger tires...
flowmaster 80 2.5 in 2.5 out 3" tips(single muffler dual outlet)
K&N
holes in Intake Canister (that filter is in, dunno what its really supposed to be called)
What is a recommendation???
thanks
92 RS
3.1L
5spd
K&N
thanks
Car: 1992 RS
Engine: 3.1L V6
What's up? I launch at like 2000 rpms in my 3.1 five speed. I seem to have the one tire wonder as well and even at that rpm the tire still spins a little( Kind of bald tire...). I know it sounds pitiful but right when you finally connect, you can floor it right away. At least on my car. Hope i helped a little bit!
1992 Polo Green RS 3.1L K&N conical and working on the ram air....
"Yeah, it's a V6 SO WHAT!?"
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
My experience is that both tires will hook up if they are good. If one side is going bald then it will spin because it has less resistance... posi will do the opposite. SO it isn't that big of a disadvantage. As far as dumping the clutch, don't do it that often. I don't drop at much more than 1500 RPM I find that frying the tires just slows me down. My experience is with the LG4 so it's a little different, maybe 2000-2500 will suit you just fine.
I have read in numerous car tests that with a manual small amounts of wheelspin actually produce faster 0-60 times. If you have access to a g-tech try it out. I'd like to see if that theory actually holds water.
With my 91 mustang and my son driving it, he leaves on the rev limiter about 6K. I also have slicks and some suspension work. The car gets 1.55 short times and both wheels come off the ground (I have pictures).
Try that sometime and see what happens.
Pete
Pete
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
your right I drive a 14 year old 1.3L
been a while since I drove a piston motor and your guys torque curves are wierd to what I drive
imports are cool - ricers suck
ICQ 4116192
AIM RXspeed87
Got rotary?
header, intake, ported TB.
soon to have ported intake, lighter rotors,ported motor and a T-66
ICQ 4116192
AIM RXspeed87
Got rotary?
the tires have a limit on traction...you want to be right at that limit when braking cornering or accellerating to put the max amt. of power to the ground...they should be chirping a bit but not all out squalling....a little bit is ok and means your getting the most traction out of the tire as you possibly can....prolonged squalling means youve broken the traction limit and you need to back off to go anywhere in a relitivly quick fashion
1998 Cobra convertible
1 of 267 made in
white/tan leather/tan top
#388 of 3480
mods: tan bumper inserts, pirelli P7000's on all corners
my other car:
1991 Camaro RS
teal/grey 5.0 LO3
mods: 14x3 OE w/ K&N, custom exhaust w/ no muffler and resonated tip
BEATINGS WILL CONTINUE UNTIL MORAL IMPROVES
1 of 267 made in
#388 of 3480
my other car:
1991 Camaro RS
teal/grey 5.0 LO3
Car: 2005 BMW 545i
Engine: 4.4L N62B44
damn it if I could dump the clutch at 200-3000 rpms without bogging like you guys I would. but damn it I dont have any power till about 3000 or so. and really kicked in at around 3500 all the way up to about 7500 or so
but from a friends camaro I think he pulled the best launch at around 3500 or so though I dont know if he was slipping the clutch or not.
ICQ 4116192
AIM RXspeed87
Got rotary?
ICQ 4116192
AIM RXspeed87
Got rotary?
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
<font face="Verdana, Arial" size="2">Originally posted by buddman91rs:
</font>
</font>
Car: 2005 BMW 545i
Engine: 4.4L N62B44
nope no turbo for me
I wish though
one should be comming soon though
I am running in the 15's right now
for the most part pull a 15.4 but best is a 15.1
what about you man?
I wish though
what about you man?
Nope, no turbo for me either... hahahaha
not a bad idea though...
I'm not sure what i run but I estimate bout, 15.5 or a little more....
thats a rough estimate though...
i'd love to take it to the track some time. but, alas, no time, and i'm afraid i'll break something...
Car: 2005 BMW 545i
Engine: 4.4L N62B44
guess I shoulda rephrased it
guess these cars dont come with turbos right??
oh well
you running an 8 or a 6?
8 I take it?
oh well
8 I take it?
nope, its a 3.1L 92 RS w/2.5 in and out 80 series Flowmaster
K&N (most power adder... hahaha)
slashed box... (seems to actually have helped)
3.42 rear
5spd
she's pretty quick... i may have overestimated her when i said those times though... judging by your response...
what do you think she might run???
3.42 rear
5spd
Car: 2005 BMW 545i
Engine: 4.4L N62B44
I have no clue
I just from what I heard in the v6 forum most of them run in the 16-17 range
you have aim or icq or something
if you want to talk my info in the sig
ICQ 4116192
AIM RXspeed87
Got rotary?
ICQ 4116192
AIM RXspeed87
Got rotary?
well my best way is just to ease off the clutch as if i where takeing off normally and when clutch is fully out just nail it. I am dealing with a 305 TBI firebird with a set of richmond 3.73s and a posi unit. It may not be the best way but n e oher way couses my tires to break free and i dont like doin that at all. Even after im rolling and i nail it they break loose, i love them gears.....
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
darwinprice
17
Oct 11, 2015 11:51 PM
