Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
92 lb9 auto z vs 06+ civic si coupe
Old Jun 8, 2012 | 06:10 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Just curious how my z28 would run with one of these from a dig. My car has :in magnaflow cat 3in magnaflow catback 10deg initial timing air foil 180t-stat with 200 fan switch lowered founders poly/rod lcas lcarbs founders poly/rod Panhard rod racetronix fuel pump kit on stock fuel pressure. I'm about to ditch the 2.73s for a 3.42 rear in the next weekend or so and wanna line up with a friend before and after to see a comparison. Idk how accurate they are but I've played with a few iPhone apps and ran consistent 9.6-9.8 times in the 1/8 @74-77mph but from what I've read online is that's about normal times for these cars. I know I'd get raped on a roll race but was just wondering how I'd do on a dig race.
Old Jun 11, 2012 | 08:19 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 92 lb9 auto z vs 06+ civic si coupe
Probably be about even the 06s are slower than later years. You run a low 15 and so do they. They run about a 15.1 stock but if he sucks at launching you should take him. V8s can be a bit more forgiving of bad launches.
With mods they make it into the 13's fairly easy
http://www.youtube.com/watch?v=jRYDUJIlDbg
Old Jun 11, 2012 | 10:57 AM
Screamin86's Avatar
Yeah I know they can be quick just curious how the lb9 would hold up to one.
Old Jun 11, 2012 | 11:28 AM
midias's Avatar
With what you are running in the 1/8th I am guessing it will be close with you edging him out if you launch better.
Old Jun 11, 2012 | 01:25 PM
Screamin86's Avatar
Seems to launch the best just a little higher than idle 1200. I've got some mirror drs for the trans am but I don't think I'll need them on this car for awhile lol.
Old Jun 11, 2012 | 05:38 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Those Civics are decently quick, but they've started to get fat. If he's stock, and you get those 3:42s, so long as you got some good wide sticky tires and know how to launch, you should be able to take him.
Old Jun 12, 2012 | 09:56 AM
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
Gear your Z28 and put some headers. Those stock manifolds are so restrictive, and those 2.73's need to go. With those mods your car will be tickling the 9.4 to 9.6 range. A tune and a bump in fuel PSI will unleash hidden power too! Good luck man!!!
Old Jun 12, 2012 | 10:44 AM
Screamin86's Avatar
3.42 aluminum drum rear and ls1 aluminum ds is going on in a few weeks but unless I find a screaming deal on some headers and y pipe the manifolds are staying. Not looking to put a ton of money into the lb9 since a 5.3/4l60 combo will be in it within the next year.
Old Jun 12, 2012 | 12:36 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Should take him pretty easily if you know how to prep that LB9...
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
