Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
86 z28 vs stock ls1
Old Jul 1, 2012 | 05:44 PM
boodaddy's Avatar
86 z28 vs stock ls1
i have a 86 camaro with a small block 400, worked vortec heads xe284 cam, 3k stall in a 700r4, rpm airgap longtubes, and holley 750 ,with 3:73 rear gear turning 295/50/15 et streets the car is not tuned we just got it put together...and its full weight......the car im racing will be a 02 ws6 with a lid and catback oh and its a clutch.........sorry for if you have been through this so many times but i built my first car and have yet to see what it has
Old Jul 1, 2012 | 08:42 PM
Guest
Guest
Posts: n/a
Re: 86 z28 vs stock ls1
Get it "done" first....rookies...
Old Jul 1, 2012 | 09:59 PM
boodaddy's Avatar
well i was just wondering after we get it tweaked right is it worth trying to run a ls1....
Posted from Thirdgen.org App for Android
Old Jul 1, 2012 | 10:06 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
just run it and find out. Dont talk crap to the LS1 beforehand that way if you lose you wont looks stupd. Dont be afraid to race and find out. Do it at the track so its fair and safe. I dont understand why everyone has to get reasurance that they will win before they even try. Just go have fun and dont be an ***...
Old Jul 1, 2012 | 10:11 PM
boodaddy's Avatar
thanx ill run it but we dnt have a track we have a wide road that is next to a train track that is closed down so sometimes the cops don't bother us....but Im not being a a** but it was fir 200 bucks and i dnt wanna just give my many away........
Old Jul 1, 2012 | 10:12 PM
boodaddy's Avatar
money away... sorry i have the android app
Old Jul 1, 2012 | 10:14 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
didnt say u were being an a** i was advising against being one before running. And why would you bet $200 if u were so unsure that you would have to post this thread.....
Old Jul 1, 2012 | 10:18 PM
boodaddy's Avatar
well Im 19 years old building my dream car and i thought that this forum was to ask you more experienced guys questions and learn from things that you have done in the past....i was told that my motor should make 450 horsepower but you know more than i know so i was looking for guidance
Old Jul 2, 2012 | 02:42 AM
lozantius82's Avatar
Car: 89 Camaro Iroc Z
Transmission: MK6 World Class T5
Axle/Gears: 9 bolt had 3.45's, now 3.27 gears
Don't listen to that douche man!!! Yes you got a good chance of winning, 450 hp is good enough to take down a LS1!!!
Old Jul 2, 2012 | 11:19 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
i have a 86 camaro with a small block 400, worked vortec heads xe284 cam, 3k stall in a 700r4, rpm airgap longtubes, and holley 750 ,with 3:73 rear gear turning 295/50/15 et streets...
You will eat him alive depending on your carb tune and heads. Did the Vortecs have any work done to them? Your running a 400-SBC with a 240/246 507"/510" @ 110 camshaft, good stall, good gears, with 295 EZ streets. Again, if you know how to tune the carb, and if the heads had any additional work done to them, you will eat him alive...
Old Jul 2, 2012 | 11:50 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
You will win, IF, the motor is tuned right. If its not tuned right at all, you might only make half the power you should. When I first put my car together, I couldnt even spin the tires. Now it has no problems spinning them up to 40 mph. The tune can make all the difference. I would spend a little time tunning it first. If its too lean or way too rich you can wreck your new motor also. Or if the timing is way off.
Old Jul 2, 2012 | 12:28 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
ls1 car is gonna win.
Your lack of experience is gonna hurt you, even if your motor is more powerful.
You dont even know how to drive the car you built yet.
Dont see, how u can go lose cash. Ur money. a lid,catback, and tune if he has one is gonna give you a run for money literally. The guy prolly has alot of exp. Driving his car and racing it
sounds to me like your build just increased by another 200$.
Still though, u got a good chance of winning. GL
Old Jul 2, 2012 | 11:23 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
those vortecs better be well worked over or you'll be around 400 hp tops.
Old Jul 3, 2012 | 09:20 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
With Big Hammer
Either a smaller cam or larger head would work good.
Spend your $200 and get it tuned and curved to perfection if you cant.
Then go run.
Youll have plenty of tq advantage on him but those LS1s breathe well up top yours wont. Again, tune it well if you can get it to leave should be a good race.
Old Jul 3, 2012 | 09:51 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
If you can drive the car then you shouldn't have any problem taking down a near stock LS-1. But its all bench racing until the cars are lined up. Good luck.
Mark.
Old Jul 3, 2012 | 03:22 PM
boodaddy's Avatar
thanx guys well we raced and from a dig i can't get the car to stop spinning so he's gone everytime its like I'll roll out of the hole and then give it a little gas and it still fishtails to the right......but from a 40roll to about 100 or so i got 3 quarters of a car but but i got afraid of the car because the suspension sways back and forth so i let off but honestly i gotta get familiar with the car and i Dnt know if its true but car behind us said even on a 40roll the tires still spin a little....
Old Jul 3, 2012 | 03:23 PM
boodaddy's Avatar
all in all before i let off i won....
Old Jul 3, 2012 | 05:06 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Well like I said, If you can drive the car you should outrun him... My car has radials on it and I have to really peddle it off the line. If a buddy drives my car it will blow the tires off because he doesn't know the car, You will learn to launch your car better the more you drive it. Congrats on the win.
Mark.
Old Jul 3, 2012 | 09:57 PM
Axle/Gears: 4.11
You need to heat the tires up good then leave.
Track is the best place to get it to hook good.
No way at 40 with a D.R. it should be breaking them loose
Whats your tire pressure (re the swaying)
Old Jul 3, 2012 | 10:00 PM
boodaddy's Avatar
thanx it scared me and i heated the tires up but it took so long for people to stop looking at his trans am
Old Jul 3, 2012 | 10:43 PM
big hammer's Avatar
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
find some good 215+cc runner heads for that 400 and hang the **** on!
Old Jul 4, 2012 | 12:34 AM
boodaddy's Avatar
tire pressure 17 pounds
Old Jul 4, 2012 | 08:17 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
A stock LS1? 300-350Hp is enough to take it down a LS1. I run 13.3-13.50's for the most part and give any Stock LS1 equipted Camaro/TA a run for its $$ every time. (I would guess I have arround 300Hp) Modded LS1's are a little dif. But still no better way to find out then to race them.
Old Jul 4, 2012 | 10:25 AM
Kevin Lee 487's Avatar
Car: 1999 Trans Am Ram Air
I swore peak pressure was at 32psi? The PSI of the tires rises when it gets warm, but 17 seems really low.
Old Jul 4, 2012 | 12:06 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
17 to 19 psi is about about right for a drag radial..
Mark.
Old Jul 4, 2012 | 12:46 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Awsome win!
Im at 18psi for a drag radial. Thats just the perfect combo for me so I dont light them up or dead hook and bog the car. Everyone launches different but start arround 18-20 then if you spin keep taking it out .5-1psi at a time till you get it where you want. Track temp/quality plays a big roll too.
If your at the track always check temp about 2-5 min before you run. A 1/2 psi + or - will make a difference when your looking to dead hook or spin just for a split second if you have small gears.
I know I don't have nearly as much Tq as you guys have, but I have a open rear and leave with boost already spooling. 1.90's 60ft time and never have I spun the tires at all since I got the burnout routine down pat. The key is avoid the water box, then back into it spin the tires a little to clean them off then do your burnout and make sure it hooks at the end of the burnout box. I had problems earlier this year with hooking because I would drag water up with my front tires, so that after the good burnout, the slick would get wet from the front tires draging up water. Doesnt take much water to have problems.
Just my 2 cents.
Old Jul 4, 2012 | 02:50 PM
Mark.
Thanks, didn't know that
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
