Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
My lb9 mod list what is she going to run?
Old May 19, 2013 | 12:12 PM
89stkformula's Avatar
Car: 1989 formula firebird
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
1989 formula lb9 tpi
factory options
g92
g80
n10
m5
aftermarket mods
Edelbrock T.E.S headers
flowmaster cat-back exhaust
Nos 05151 100-150 wet shot
crane gold 1.6 roller rockers
accel dizzy
msd 8mm wires
k&n drop in filter
bbk fuel pressure regulator
NJK UR4 spark plugs
1LE aluminum driveshaft
So what do you guys think she is going to run I am hoping to get her to the track by the end of June.
Old May 19, 2013 | 02:54 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: My lb9 mod list what is she going to run?
13.8 on the bottle
Old May 19, 2013 | 07:12 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 89stkformula
So what do you guys think.
Get an LS1.
... j/k, I agree with TPI-Formula350-, high 13's on the bottle.
Old May 19, 2013 | 08:37 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I have a total of $1150 in all those mods looking to get high 12s with about $1500 invested in mods.
Old May 19, 2013 | 09:06 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Let me make sure I'm understanding. Your saying you want to spend another $350 and shave another second off your E.T.?
Old May 19, 2013 | 09:14 PM
Car: 89 Formula 350
go with a 250 shot, should do it.
save a few bucks for the tow truck.
Old May 19, 2013 | 09:17 PM
jas2730's Avatar
Old May 19, 2013 | 09:18 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I am thinking of porting everything myself so that is free and buying some used slicks on craigslist should get close to where I want to be.
Old May 19, 2013 | 09:20 PM
Guest
Guest
Posts: n/a
Nah. 13.2 after all is said and done
Old May 19, 2013 | 09:21 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
$1500 invested in a 12sec lb9 is my goal. Probably not going to happen but I will try for the hell of it.
Old May 19, 2013 | 09:22 PM
jas2730's Avatar
Your not getting into the 12's with stock cam and heads.
Old May 19, 2013 | 09:23 PM
jas2730's Avatar
Good luck with that.
Old May 19, 2013 | 09:32 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
believe me I will be happy with 13.2 but it's more fun to shoot for a 12.99. lol
Old May 19, 2013 | 09:37 PM
jas2730's Avatar
Hope for 13.2 but expect 13.5.
Old May 19, 2013 | 09:47 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I probably could get a used set of l98 heads for $100.
Old May 19, 2013 | 10:05 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
hahaha I don't think I've ever literally laughed that hard out loud while reading something.
Old May 19, 2013 | 10:06 PM
transamws6's Avatar
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
Nahh not with stock 305 ..i got lots mods on mine t56 and 3:42 nd some good suspension work ..nd i still have trouble with lt1s depends how i shift..u need a 350 buddy or 3.8 turbo
Old May 19, 2013 | 10:10 PM
jas2730's Avatar
I just replaced my 3.42's with a set of 4.10's. Made a huge difference with my convertible. (305, T56)
Old May 19, 2013 | 10:11 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
We've sent a 305 with HO 305 heads and a mild cam into the 12's on a 100 shot with descent drag radials, 4.10s and an air gap intake.
Old May 19, 2013 | 10:15 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
transamws6 are you running nitrous?
Old May 19, 2013 | 10:17 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
If I blow up my lb9 I will build a 383 to replace it!
Old May 19, 2013 | 10:29 PM
jas2730's Avatar
When you say mild cam what are you saying? I'm assuming around .480 to .500 lift which is by most peoples standards mild. That being said his peanut cam is nowhere near those specs. More like .400 lift with the 1.6 rockers which isn't going to get it done.
Old May 20, 2013 | 01:02 AM
transamws6's Avatar
No nitrous ...and thats crazy how gears make a good difference..
Old May 20, 2013 | 01:06 AM
transamws6's Avatar
Sounds like a 305 from hell ...should run ls1 nd record it
Old May 20, 2013 | 06:51 AM
Guest
Guest
Posts: n/a
Throw those headers in the trash and get LTs, dont worry theirs no motor jacking or fabbing required.
(mufflex Y-pipe)
-you WILL need a heated 02 and a mini starter
Old May 20, 2013 | 07:20 AM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I thought the 88-89 lb9 5speed and l98 had the .415/.430 cam from the factory.
Old May 20, 2013 | 07:25 AM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I went with the tes headers because I really want to keep the stock look. I just want to build a 12.99 sleeper car with only $1500 dollars in performance mods.
Old May 20, 2013 | 07:37 AM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I did get some good deals on used and new parts from ebay ,swap meets and members on this site but if I can achieve this goal I can set up a budget blueprint for lb9 owners.
Old May 20, 2013 | 03:04 PM
Car: 89 Formula 350
13.2 isn't going to happen with stock heads and stock cam in an lb9.... if it does its going to cost more then your $1500 budget.
Old May 20, 2013 | 03:05 PM
Car: 89 Formula 350
Yes.... that's a tiny cam.
Old May 20, 2013 | 07:24 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
That made me laugh pretty hard my wife came in the room to check on me lol
Old May 20, 2013 | 07:39 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I just read this post from kustomiroc
Ran a 12.84 on Nitrous - 305 TPI
Hi guys I'm back
I finally hooked up my nitrous and my MSD Digital 6. Thanks again to Mike Metzler (Desert86Iroc) for some tips. I went to the track Saturday and posted 4 time trials.
14.34 @ 95.75 on the motor. This is right of the trailer. This is usually what I run.
14.24 @ 96.17 this was good I picked up at least a tenth off of my regular track times.
13.34 @ 106.13 Wicked run hit the nitrous at about the 990 to half track mark.
12.84 @ 107.74 AWESOME, I hit the bottle about 20 to 30 feet out as I was scared to grenade the little 7.5 10 bolt.
I have never had so much fun. I have raced this car for 3 seasons now and have gone from high 15's down to 12's on my TPI 305 with a 166 000 kms on it. Stock cam and heads and still running the same timing chain and gear.
Go figure.
I used the 5151 NOS kit but put in a 53 and 70 jets. I think they are a little larger than the 150 hp jets.
I came out Sunday and made 4 more passes
off the bottle.
14.38
14.31
14.34
I dialed in a 14.32 and lost to the guy next to me. I ran a 14.316 and broke out. The nitrous didn't hurt the consistency too much.
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old May 20, 2013 | 07:41 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
If kustomiroc can run 12s on stock heads and cam so can I !
Old May 20, 2013 | 07:48 PM
Brando5641's Avatar
PLEASE take a video camera with you for proof of the time clock or so we can all see a rod hit the eject button.
No offence but i dont see it happening. It will be cool if it does but....
Old May 20, 2013 | 08:00 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
My wife will definitely record my runs. I hope she does not blow up but if she does I can use all my mods on my 383 build.
Old May 20, 2013 | 08:07 PM
My wife will definitely record my runs. I hope she does not blow up...
Why would your wife blow up...?
I'm sure your LB9 will do just fine...
Old May 20, 2013 | 08:38 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
lol
Old May 20, 2013 | 10:17 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Just have fun that's all that matters. I wish I could afford to drag race still. I guess I could if I was doing what your doing but I always had to have BB Mopars. Not cheap to build or blow-up.
Old May 20, 2013 | 10:27 PM
jas2730's Avatar
P*** on Mopars!
Old May 20, 2013 | 10:40 PM
rawley2's Avatar
Originally Posted by jas2730
P*** on Mopars!
LOL, I like them all to tell the truth as long as they are American made. Lets face it Ford does make a good truck. But them Rustangs have to go. LOL
I hate fart can imports with the shopping cart handle on the back.
Old May 20, 2013 | 10:49 PM
jas2730's Avatar
I have a SRT 4 neon, Mitsubishi 3000GT, Dodge Durango, and 2 IROCs. So I'm pretty open to all manufacturers. Except Ford that is.
Old May 21, 2013 | 12:12 AM
  #42
transamws6's Avatar
But muscle cars cant turn nd they take too much gas.... Hahahahaha jk american muscle all day .. Nothing like a v8 rear wheel drive...
Old May 21, 2013 | 12:14 PM
  #43
GenX'Motorsport's Avatar
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
12's On a healthy LB9 with a 150 shot, Should be pretty easy. If the car is in proper running order. And the kid can drive and launch. Not to mention, his formula is a bit lighter than a GTA or Iroc. There was a guy on here a year or two ago. He had I think an 88 or 89 formula LB9/T5 and sprayed it in the 11's. Decent suspension, DR's and bolt ons, and alot of practice and tuning.
Old May 21, 2013 | 01:05 PM
  #44
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Good luck man ill be rooting for you! but hey if it does blow on you then you'll have a reason to build you a 383
Old May 21, 2013 | 01:11 PM
  #45
Guest
Guest
Posts: n/a
You'd need at least a 200 shot...to start.
Old May 21, 2013 | 01:55 PM
  #46
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
Thanks for the support everyone! I really hope I can get my lb9 in low 13s high 12s with only $1500 invested.
Old May 21, 2013 | 02:12 PM
  #47
Its been done. Just search on here.
Old May 21, 2013 | 10:28 PM
  #48
transamws6's Avatar
U can buy my 305 wen urs blows up since im putting a vortech in my car soon ...just throwin it out there
Old May 23, 2013 | 07:58 PM
  #49
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
well guys transamws6 sent me some bad luck lol today my wife was driving the formula today and overheated the engine and cooked it with only 62,000 miles on it. My friend has a 350 out of a 86 iroc what would I have to do to make the swap work? could I use my 305 intake with out the cold start?
Old May 24, 2013 | 01:17 AM
  #50
KMdoza7's Avatar
Engine: none
85-88 have the cold start injector, 89 was the first year that the CSI was removed. But to answer your question, yes you can use your intake, you can also use all your accessories. the main thing you have to do is put 22 LB injectors. if you have anymore questions you can PM me if you'd like. theres also some helpful info on the swap all over thirdgen,org
