dynamic compresion ratio
please help..
if dynamic compresion ratio is :
4.2:1 what octane gasoline do I use ?
4.8:1 what octane gasoline do I use ?
5.4:1 what octane gasoline do I use ?
6.0:1 what octane gasoline do I use ?
6.6:1 what octane gasoline do I use ?
7.2:1 what octane gasoline do I use ?
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
Re: dynamic compresion ratio
please help..
General rule - multiply by 10.
So your 7.2:1 DCR needs 72 octane.
Car: 85 Z28/87 IROC-Z/92 B4C
Engine: Twin turbo LS9/SC LS9/L98
Transmission: RPM T56/T56 Magnum/700R4
Axle/Gears: 9"/Dana 44/10 bolt
Good for you for actually being concerned with dynamic compression ratio. IMO the dynamic compression ratio makes an engine. There are many factors when choosing a target dynamic compression ration. When I was building my 441ci LS7 for my Z06 I wanted to build it to be on the edge of what pump gas was capable of. My previous LS7 build in my C5 was very aggressive and required E85 which became very annoying. Through my research I found that around 8.5:1 was roughly the end of the cushion for 93 octane. I'm sure you could push it further on certain engine combinations with more efficient combustion chamber designs. But I was happy with sticking to 8.35:1 dynamic which ended up being 13.8:1 static. The engine runs exceptionally well. It made 655rwhp and 585ftlbs on 93 octane and took 26 degrees of timing with no issues at all. No signs of pre-detonation, no issues overheating. No issues at all honestly. I drove the car thousands of miles and many road trips. Even with only a 3.42 gear in the rear the car ended up running 9.90@143mph in the 1/4 NA and 8.90@160mph on a 300 shot.
